Author Topic: matsumin valvecaster issues  (Read 544 times)
Mini612
« on: March 16, 2020, 01:47:26 AM »
Hi guys, I am a newbie!  Decided to take on this project as I’m home bounded and I have a few things laying around the house.  I decided to put this tube valve over drive pedal together as it didn’t look difficult and I have some parts laying around.  This is the first time I am putting together a stomp pedal.
What’s the problem?
 No sound or output going to my amp simple no sound, maybe a little hissing sound but no hums, no static sounds.  I didn’t have any 3dpt 6-pin switch so I used a little on/off that I had left over from a car project. Yes the tube lite up.  But no sound when I turn any of the knobs.
I’ve looked at the schematic many many times to check my resistors and capacitors placement  and they appear to be in correct locations.  Did I miss something?  Any help would be appreciated.
Pics below of the schematic I used and mine.  And yes, I know mine is messy, and the soldering could use more work, but I’m still learning and could appreciate any help to get this thing working.
« Last Edit: March 16, 2020, 01:49:16 AM by Mini612 »
willienillie
Re: matsumin valvecaster issues
« Reply #1 on: March 16, 2020, 02:34:55 AM »
What voltages (DC, relative to ground) do you get on each of the tube pins?  What kind of tube are you using?  Are you sure it's good?
mozz
« Reply #2 on: March 16, 2020, 07:48:14 AM »
Can't really tell from the picture, pins are numbered clockwise when looking at the bottom.
Mini612
« Reply #3 on: March 16, 2020, 09:06:28 AM »
I do have a few 12au7 laying around and they’re all suppose to be good.  I’ve tried several tubes and the same thing is happening.  Yes I counted the tube pins clock wise, like the pictorial schematic.  I have tried both 9v and 12v, 9v didn’t give the tube as much light so I used the 12v and that seem to light the tube better.  All capacitors are used but I tested them before using them.
rizziol
« Reply #4 on: July 28, 2020, 04:52:17 PM »
It´s hard to see the components and be sure they are all in right spot. I suggest you check the all the grounds an pot connections. I have assembled it one for me in my breadboard and that was the issue. Double checked the pots and grounds and it worked.
