3-knob Fuzz Layout for newbz?
Started by DJPsychic, March 21, 2020, 11:30:38 AM
DJPsychic
#40
Yes,
AND
No need to bring the 9V to the switch as it will connect to nothing there without the LED, so leave that out as well:
Ok. I'm going to be using a 9v jack, I just connect + and - to the circuit board then, no need to connect to switch. Will i have any issue with popping?
and I found this layout as well on Fuzz Central. Essentially same as yours just a bit rearranged?
j_flanders
#41
Quote from: DJPsychic on March 26, 2020, 09:22:53 AM
Correct
Maybe. It depends on the circuit, and if you have a 1M Ohm pull down resistor to ground before the 2.2uF input capacitor.
Same arrangement but drawn 'upside down'
The image below shows that a 3PDT switch has two positions and it shows what the 3 middle lugs connect to in either of those two positions:
lug 2 to 3, lug 5 to 6 and lug 8 to 9
OR
lug 2 to 1, lug 5 to 4, and lug 8 to 7
DJPsychic
Oh man, I'm over my head lol
Do I have to ground switch?
j_flanders
Quote from: DJPsychic on March 26, 2020, 09:36:10 AM
I've edited my post to explain but you were too quick to reply. :)
DJPsychic
Sorry Just saw it
j_flanders
If it's screwed into a metal enclosure it's grounded.
But I don't think there's a specific need to ground a 3PDT switch.
DJPsychic
Can I ground things anywhere on ground signal or Do you recommend grounding pots on the input jack for instance?
DJPsychic
#47
What is the function of the 100u? This isn't on the Small bear FF schematic...
j_flanders
#48
Quote from: DJPsychic on March 26, 2020, 12:20:51 PM
Power filter, to remove ripple from the adapter.
If you only use a battery, which is common for a Fuzz Face, you can omit it. Batteries have clean power.
DJPsychic
#49
Cool. I'll most likely have it daisy chained, afraid when I play love (if that ever happens again) I'll have forgotten to change battery  ;)
But if I do omit, I don't need to alter the layout in anyway?
Also when you mentioned adding a cap to prevent switch pop, where would that be located and is that necessary?
edit: does the 100u effect the output sound in anyway?
j_flanders
#50
Quote from: DJPsychic on March 26, 2020, 12:47:46 PM
No, you can just leave it out or just leave it in. Doesn't hurt either way. And no layout changes needed. You can put it in afterwards if you like or remove it later on if you want.
Resistor, not cap.
The 2.2M resistor, right before the 2.2uF input cap, is the pull down resistor to prevent switch pop. You can also use 1M or 470k.
This post explains possible reasons for that 100uF cap, even when using a battery:
https://www.diystompboxes.com/smfforum/index.php?topic=113734.msg1054057#msg1054057
The entire thread is a good read.
DJPsychic
Awesome thank you so much. Sorry I'm trying to learn as much as I can. I've had the iron on for over an hour afraid to make the initial solder, just gonna go for it lol
So without the R before C1 I'll have pop?
I'm assuming the resistor as a slight effect on output signal?
j_flanders
Quote from: DJPsychic on March 26, 2020, 02:35:35 PM
It could.
Here's a page explaining why you can have pop: http://www.muzique.com/lab/pop.htm
DJPsychic
I decided to just go with a 9v. I have 9v + and - directly into board. Do I need to wire 9v to input jack?
Electric Warrior
Yes,
AND
If you're concerned about popping, you shouldn't wire it up like that. Grounding the input in bypass is hardly any more effort and the superior way achieving true bypass.
j_flanders
#55
Quote from: Electric Warrior on March 26, 2020, 05:45:01 PM
Correct. It's my fault. I just took any 3PDT bypass image from Google to show how you could omit the status LED part.
It were better if I had choosen one with input (and output) grounding.
So, here you go:
Or
DJPsychic
#56
Ok...here's my ghetto drawing of everything I did (wrong)
I tried to color coat all of my connections
nocentelli
#57
You need to get rid of the pink wire labelled  L1 (that you have connected to +9V on the board). Connect the black battery snap wire to input jack L1 (the ring connection) instead of the board. The rest looks OK.
DJPsychic
Quote from: nocentelli on March 27, 2020, 12:56:35 PM
Ok, I have removed "L1" from +9v
So then what replaces the ground for the board after I remove battery snap??
nocentelli
#59
You have a stereo input jack but a guitar jack (plug) is mono. The battery negative is connected to the ring connection on the input, and there is a connection between the input ground lug ("sleeve") and the circuit board via that pink L2 wire. When you insert the guitar jack into the socket, it bridges the ground/sleeve and ring contacts and connects the battery negative terminal to the circuit. The +9v red wire from the battery is permanently connected to the circuit, but the power circuit is only completed when you have a guitar cable plugged into the input: This prevents the battery from draining when not in use (IF you always remember to unplug the input cable when you finish playing).
