Split n Blend Quick Questions
Started by seten, April 13, 2020, 03:38:52 PM
seten
Hey, I need to blend a guitar and bass signal together. Is this my best option? Should I change around the caps for the bass side?
I only have 2n5458's, guessing those will work but wanted to be sure.
Most importantly, since I dont have a send and return how do I modify it? Seems like I would just put guitar in where it says input and bass in where it says send and then pull the return from somewhere in the circuit but i dont know how jfets work yet so I cant figure out where.
Oh and also what are those little red squares? Does that mean im supposed to cut out that part of the tagboard?
http://tagboardeffects.blogspot.com/2012/02/split-n-blend.html?m=1
idy
The red squares are cuts in the copper strips. I don't think you want a splitter, just a blender. That's called a mixer.
patrick398
Maybe something like this will be better suited:
https://tagboardeffects.blogspot.com/2013/01/2-channel-mixer.html
Are the bass and guitar being mixed and sent to the same amp?
seten
Quote from: patrick398 on April 13, 2020, 03:49:16 PM
Thanks! I do like the idea of having a single blend knob instead of two level knobs though - I'll do some digging for something like that. Or could I use the one you linked with some sort of dual pot?
Normally I split my signal and put one through an octave into a bass amp and the other goes to a guitar amp. For this theyre being mixed together and that unifed signal is panning between the two amps with a flying pan clone.
I always wondered why any active circuitry needs to be involved at all in a mixer - whats wrong with just using two pots wired as voltage dividers?
antonis
Quote from: seten on April 14, 2020, 02:19:09 AM
Impedance (mis)matching.. :icon_wink:
Consider pots wipers shorthed.. 1st pot out goes to 2nd pot in (and vice-versa) through both upper resistances (Lug 3 to wiper).. So, each one of them loads the other one..
seten
Quote from: antonis on April 14, 2020, 05:34:50 AM
ah i (think) i see. on a similar note, I'm splitting my signal with a passive box thats just 3 jacks with all the tips connected, sending one to a bass fx chain to bass amp and the other to guitar fx chain to guitar amp. I havent noticed any issues but would I be better off with a buffered splitter? Not concerned about volume loss since im not switching it but could I be getting some tone suck or noise that I've just gotten used to?
iainpunk
Quote from: seten on April 14, 2020, 12:08:33 PM
i have done something similar for my band for a long time, i just used a boss pedal before the splitter and just left it off, this was adequate enough as a buffer.
cheers
antonis
Now you're talking about spiltter..
(and not mixer, as previously..)  :icon_wink:
Passive splitting works quite well, as long as splitted signals go to entirely different inputs..
For almost infinite input imedances, splitting is almost perfect..
Both Bass & Guitar amps exhibit quite hign input impedance so there practically isn't any interaction between splitted signals..
seten
