Author Topic: Same pedal, different Bypass  (Read 1654 times)
antonis
Re: Same pedal, different Bypass
« Reply #20 on: April 17, 2020, 05:32:42 AM »
You might use different lug numbering.. :icon_wink:
I use to number them like post #4 here: https://www.diystompboxes.com/smfforum/index.php?topic=124217.0
Anyway, check for any resistance value continuity between IN or OUT tip and board IN, and IN or OUT tip and board out (Vol pot..)
DJPsychic
« Reply #21 on: April 17, 2020, 12:28:26 PM »
Which range of resistance should I be setting my Multimeter to?
antonis
« Reply #22 on: April 17, 2020, 02:00:00 PM »
Start from the higher and descend...
(but you have to buy an auto-range DMM..) :icon_wink:
DJPsychic
« Reply #23 on: April 17, 2020, 02:53:10 PM »
Ok, No readings from TIP in/out
antonis
« Reply #24 on: April 18, 2020, 03:47:52 AM »
We can now shake hands that there isn't anything inside bypassed signal chain that can cause signal volume drop.. :icon_wink:
DJPsychic
« Reply #25 on: April 18, 2020, 08:48:23 AM »
Haha yes, thank you for all your help! I think I’m going to disconnect the 9v jack and just use battery snap like the “Louder” pedal. Maybe replace input/output jacks just to be safe.
Thank you for your patience and guidance man!  :D
DJPsychic
« Reply #26 on: April 19, 2020, 01:12:53 PM »
Edit: changed jacks. Solved problem.
Is there a way to test jacks so I don’t have to go through this again?  ::)
« Last Edit: April 19, 2020, 01:44:35 PM by DJPsychic »
antonis
« Reply #27 on: April 19, 2020, 06:16:15 PM »
Check for infinite resistance between sleeve and tip..
