Author Topic: DURING Quarantine - anything going on?  (Read 5086 times)
Re: DURING Quarantine - anything going on?
« Reply #20 on: May 03, 2020, 01:15:49 PM »
Overhauled the power supply of a hifi tube amp i built in 2004, finished wiring up and testing a HoSo 56 guitar amp i set on the shelf in 2016. Presently vegetable garden prep,  ton of cooking with a much smaller, limited palette, some woodworking on the go...
dave
Greenwichpaul
« Reply #21 on: May 03, 2020, 03:20:37 PM »
Sorted out my coffee machine.
THe main issue was a short in the IEC mains cable? Whoever heard of a fault in a mains cable? Plus the coil in a little solenoid valve failed. Switched in one from my main machine and it works fine now, new one ordered.
I love that there's this coffee machine subculture, with all the bits - pumps, valves, etc  - being made in Italy for not much money. If only as many British companies were still making speakers and transistors. Come to think of it, how come the Italians are still making Jensens when Celestions are now made in China?
blackieNYC
« Reply #22 on: May 03, 2020, 05:01:56 PM »
Writing and recording songs with some friends. So far so good. We write a bunch of lyrics in a zoom meeting, divvy them up and write a song. Then everybody tracks theirs and posts it up in a Dropbox.  Then you download someone else’s song and overdub.  Only need a cheap interface and maybe a mic. We’re using Reaper software which is free for 60 days.
Ripthorn
« Reply #23 on: May 03, 2020, 05:30:49 PM »
Finished all the build docs, code, schematics, etc. for my latest project, the DiSH (https://www.diystompboxes.com/smfforum/index.php?topic=124380.0). Posted a video demo as well. It's an analog sample/hold supplied with a digitally-generated control voltage. Has tap tempo, tempo divisions, pattern setting, etc. Check it out! Build one! I've got gerber files in there, and I've got a few leftover PCB's if anyone wants to build one but doesn't want to place an order with JLCPCB, OSHPark, etc.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
« Reply #24 on: May 04, 2020, 03:26:42 AM »
anotherjim
« Reply #25 on: May 04, 2020, 04:13:03 AM »
So that's how they make Shredded Wheat!
Croeso i Diystompboxes.
If they didn't hear you then you didn't say it.
Ben N
  • Total likes: 431
  • Ben N. - really! Now Israel, once Baltimore
« Reply #26 on: May 04, 2020, 05:40:21 AM »
Just snagged and salvaged a dead microwave yesterday. Thinking now about what to do with the transformer. Also, spending an inordinate amount of time wondering what happened to the Tayda discount.
Scruffie
« Reply #27 on: May 04, 2020, 05:52:01 AM »
Another is working on the "version 2" of the Druid DigiDelay. I can't say much more about that one right now, except to say that it fixes the biggest problems the original had.
Adds modulation!?  :D
As someone with a vintage EHX 2 & 16 second digital delay in for repair, can I make a suggestion for an 'infinite repeats' (phrase looper) foot switch.
Apart from the above repairs, I quite badly burnt my leg last weekend so aside from oil painting I'm mainly doing circuit simulations from bed at the moment. Mainly filters and the like but also for a single supply TDA1022 version of the CE-1 as a forum project as that dual supply & MN3002 seems to be a stumbling block for a lot of people lately, personally I never got the fascination with the pedal.
« Reply #28 on: May 04, 2020, 08:07:39 AM »
You could get some transmitting tubes and make yourself a kilowatt audio amplifier.  Not sure what you would use for an output transformer but there are some people who would use a couple of more power transformers with the line voltage sides connected together so you could have a push-pull transformer made out of two power transformers.  But beware - you may have several kilovolts from this supply that could turn into killervolts.  You may need to wind a few turns for the speaker winding.
cloudscapes
« Reply #29 on: May 04, 2020, 10:35:14 AM »
Playing around with synth circuits. Lunettas, and a benjolin. Hope to put two of the latter in a wood box as a self-contained noise box!
Sort of interested in re-iterating on my old digital delay again. I'd start by porting it from PIC32 to ARM, and also try and fix some of the inherent flaws the old circuit has. Namely headroom. I'm not as proficient with clean analog design as I am coming up with weird audio-destroying effects.
« Reply #30 on: May 04, 2020, 12:25:02 PM »
NSFW
Oh, the irony!
Have to watch out or could end up here...
...one things leads to another but then that's another song.
dave
« Reply #31 on: May 04, 2020, 01:06:46 PM »
I started doing these before the quarantine, but I've been continuing videos of playing my main instrument :P
"I'm not sure what "serious design flaws" you see. Does it explode or poison your dog?" - PRR
« Reply #32 on: May 04, 2020, 02:50:00 PM »
^awesome drumming man..love it... 8)
newjackruby
« Reply #33 on: May 04, 2020, 03:23:53 PM »
Germanium ( MP21A) Fuzz Face using the Mad Bean Mangler pcb. I could only get the Q2 bias up to just under 4v on the stock parts, but decided to leave it that way because it sounds gnarly!
« Last Edit: May 04, 2020, 03:25:34 PM by newjackruby »
« Reply #34 on: May 05, 2020, 06:31:43 AM »
I'd like to say I wish I could do circuits and designs right now but I can't.
Struggling with my mind, so instead I've been gardening and getting my neck red.
Enjoying the fresh air and I have lots of flowers to show for it.
I'll be back on the circuits soon hopefully. I'm storing ideas meantime and possibilitys.
Stay safe ya'll.
Rich
I've been struggling mightily with my mental health during this quarantine, so I'm trying to keep some open-ended projects going to keep myself moving forward.  This one might make you smile, Rich.
I'm working up an envelope follower experiment rig using a method I'm just going to call hybrid breadboarding, in which some subcircuits get soldered up into a permanent form, despite there being no final design in mind, while other stuff gets breadboarded in a more traditional manner.
That's most of a Mutron III build from the tagboardeffects layout, with the filtering parts left off.  I have another board that rides on top with a charge pump and space to solder a permanent version of anything that ends up delighting me later.
"I want to go back to being weird. I like being weird. Weird's all I've got. That, and my sweet style." --Maurice Moss
antonis
« Reply #35 on: May 05, 2020, 07:31:25 AM »
You might be the only person I know who uses stripboard on top of breadboard, Eric.. :icon_wink:
(you should own a much cheaper workbench mat, shouldn't you..??) :icon_lol:
« Last Edit: May 05, 2020, 07:48:33 AM by antonis »
« Reply #36 on: May 05, 2020, 07:44:07 AM »
Part of it is a recognition of the fact that I have more than once had to buy a new breadboard in order to prototype something because my existing breadboard space is taken up with semi-permanent experiments that I can't bring myself to tear down.  :icon_lol:
An example:
The one below stayed on my breadboard for nearly 20 years!
I don't use my breadboards efficiently or even correctly, it seems.   :icon_razz:
« Last Edit: May 05, 2020, 11:51:40 AM by EBK »
« Reply #37 on: May 05, 2020, 10:38:17 AM »
starting to look a bit like cordwood there, Eric. be careful.
Now battery powered. Remove plug when not in use, please.
anotherjim
« Reply #38 on: May 05, 2020, 04:49:01 PM »
Lockdown coincided with making a start on various home maintainance jobs.
Have done very little of a musical or electronic nature.
Attempt to grow an apocalypse beard vetoed by She Who Must Be Humoured.
« Reply #39 on: May 05, 2020, 04:57:39 PM »
I only shave now when it is time to prepare for a Costco run.  That informative chart from the CDC showing Hitler successfully wearing a mask is mockingly inspiring.   :icon_razz:
