Author Topic: "Boutique TS" Breadboard issue  (Read 4394 times)
antonis
Re: "Boutique TS" Breadboard issue
« Reply #100 on: May 19, 2020, 09:27:59 AM »
I might didn't make myself clear when said:
plz post the final layout of your build..
Layout posted above CAN'T work..!!
(there is no Ground else than last bottom row..)
So, if you have the kindness, post the last WORKING layout..
(sorry but I can't help you without knowing the actual situation..)
antonis
« Reply #101 on: May 19, 2020, 09:49:35 AM »
Something tells me you'll re-re-repost the same layout, so check what's happening with 1K feedback resistor..
(the one between pin 7 & pin 6, through jumper..)
« Reply #102 on: May 19, 2020, 10:55:18 AM »
.... and with proper diode/s connections.
Now battery powered. Remove plug when not in use, please.
DJPsychic
« Reply #103 on: May 19, 2020, 11:20:49 AM »
antonis
« Reply #104 on: May 19, 2020, 02:54:36 PM »
Did you check for 1k resistor proper connection/value..??
DJPsychic
« Reply #105 on: May 19, 2020, 03:13:16 PM »
« Last Edit: May 19, 2020, 07:39:54 PM by DJPsychic »
antonis
« Reply #106 on: May 19, 2020, 04:28:42 PM »
[deleted]
Never mind.. :icon_wink:
