Speaker without mouning holes
Started by ljudsystem, May 31, 2020, 11:36:38 AM
ljudsystem
I found a small 2 inch speaker. I'm thinking of putting it in a small plastic enclosure or tin with a ruby amp but... it has no mounting holes :icon_confused:
How do I mount a speaker without mounting holes?
tonyharker
anotherjim
I found that consumer brands these days just glue them to the baffle. The outer metal ring is usually really soft mild steel & easy to drill if you want. Or you can use any old washer to clamp them with, but as Tony said, the L clamp is the proper thing because it keeps the clamping force square to everything. Little low power thing, you don't need to be too fussy, although you still want a good air seal to the baffle.
ljudsystem
I used no more nails for a car speaker.... :icon_mrgreen:
Still hanging on lol....
