Noob feeling like an idiot - could use some assistance...
Started by Grendel2000, June 06, 2020, 06:22:21 PM
antonis
Grendel2000
jfrabat
Continuity in the board will not tell you anything...  do not worry about that.
I build.  I fix.  I fix again.  And again.  And yet again.  (sometimes again once more).  Then I have something that works! (Most of the time!).
Grendel2000
Quote from: jfrabat on July 19, 2020, 06:58:01 PM
I believe you, but wow that seems counterintuitive?  Is there an easy explanation as to why?
jfrabat
Quote from: Grendel2000 on July 19, 2020, 07:06:28 PM
Continuity typically measures if there is low resistance (which there should be in, say, a wire connection).  Typically, the resistance in a conductor will be less than 100 Ohm.  Introduce a resistor in the middle, say 1K, and now your continuity test will fail.
But do a simple experiment to verify this; do a continuity test of a resistor.  Put the MM on continuity, and touch the leads to either end of a resistor (again, say, 1K or higher).  It will not beep...
Grendel2000
Quote from: jfrabat on July 19, 2020, 10:19:36 PM
Ok, I get that, but if it DOES beep between two points, doesn't that imply that the connection everywhere between is ok?
jfrabat
Quote from: Grendel2000 on July 19, 2020, 10:24:51 PM
Not necessarily...  You could have a short that makes the signal bypass a resistor, cap or transistor, and that could be the issue why the pedal is not working.
Grendel2000
Quote from: jfrabat on July 19, 2020, 10:34:16 PM
Interesting!  What would normally cause a short like that?  Stray solder joining two traces maybe?
jfrabat
Quote from: Grendel2000 on July 19, 2020, 10:40:39 PM
That is the most common cause, yes, a solder bridge.
Grendel2000
So I'm not sure where to go from here.
As I said earlier, using the testing tool I get a signal at the input jack and at the lower left lug of the foot switch but I get NO signal at the leftmost middle lug on the foot switch (green wire) in either position of the foot switch and I get NO signal at either lug on the Bias (R7) trim pot.
What should I check?
Quote from: Grendel2000 on July 20, 2020, 08:24:18 AM
Good start! So signal gets in through the jack and gets to the foot switch.
This is crucial, since this takes the signal to the board. You'll only hear the signal at the green wire in one position of the foot switch not the other. On your photo, it looks like there's a bad joint on the foot switch with that green wire.
Are you using lead-free solder? It looks very dry and not shiny. Your iron is definitely still causing problems.
No, you won't, not until you've got signal going down that green wire.
Grendel2000
Quote from: ElectricDruid on July 20, 2020, 09:30:20 AM
I had issues with the iron and tips getting rough.  I got a bit better educated on proper use and care over the course of this thread and have bought some tip tinner which has helped a TON.
I'll re-solder that switch lug and see what happens.
Phend
Grendel2000, I have read this thread, but maybe missed this, the foot switch can be switched to "clean ", meaning no effect just like the guitar being plugged directly into the amp.  Are you saying that you don't even get this clean sound. The circuit shows the path, simple.  I suspect that the input and output jacks ground lugs are not connected together. Usually this is done thru the metal of the box.
  • SUPPORTER+
When the DIY gets Weird, the Weird turn Pro.
Grendel2000
Quote from: Phend on July 20, 2020, 09:46:57 AM
How would I check if the input and output ground lugs are connected?
ALSO:
I think I've identified an issue: I no longer get continuity between the lower left lug and middle left lug on the foot switch in either switch position.  I assume this means I've damaged the switch which would explain the signal stopping at the middle-left lug...
I've ordered a 2 pack of Kaish 3PDT switches that will hopefully be here Wednesday.  I guess I'll re-wire the foot switch then and see what happens...
QuoteHow would I check if the input and output ground lugs are connected?
continuity. you want a continous path between something nominated as ground [0V/earth/COMMON] and ANY OTHER POINT nominated as ground [0V/earth/common]. so set your meter to continuity [or low ohms range, or ohms if autoranging meter] and one probe to one jack sleeve and the other probe to the other jack sleeve.
jfrabat
In the meantime, if you want to test the board, you can wire the input and output cables directly to the jacks.  You will not be able to turn off the pedal, but at least you can try it!
11-90-an
Quote from: jfrabat on July 20, 2020, 10:44:42 AM
Just use alligator jacks (but not too long as to cause noise) if you don't want to break out your soldering iron again... :icon_biggrin:
flip flop flip flop flip
Standard 3PDT switches are very susceptible to soldering damage.  If any of the terminals appear to have shifted, they may not be making contact.  I have repaired a wah pedal before that had that problem from the factory.
Grendel2000
Quote from: amptramp on July 21, 2020, 07:53:09 AM
So is there a technique or trick that's best for getting the lugs soldered quickly to avoid damage?
Quote from: Grendel2000 on July 21, 2020, 03:31:29 PM
Have a hot soldering iron.  It may sound counter-intuitive (since you don't want to burn anything), but it means everything heats up quickly so you can be in and out in a second or two.  This is true of all solder joints, not just switches.  If you're spending ages anywhere waiting for the solder to flow, your iron isn't hot enough.
It's worth practising on some scrap board with some spent components.  Perfect your in-and-out technique.   :icon_cool:
