PMC - Poor Man's Compressor
Started by jonny.reckless, June 23, 2020, 05:12:14 PM
antonis
IMHO, you shouldn't try 4 transistors 'cause 3 BJTs current mirror delimits Poor - Wealthy man margins.. :icon_biggrin:
amz-fx
Nice project! Thanks for sharing!
Best regards, Jack
Eb7+9
#23
Quote from: jonny.reckless on June 24, 2020, 04:20:33 AM
I found that with a regular 2 transistor current mirror the output impedance wasn't high enough, so the bias point moved around with input signal level, causing control breakthrough and audible thumping. When I upgraded to a 3 transistor Wilson mirror it fixed this issue. I didn't try the 4 transistor mirror. Maybe I should have.  :icon_cool:
your ota is driving 5k(ac) to ground at the output - it's not a Zout issue // a plain-jane (non-cascoded) discrete ota will more than do here ... i'm not asking for nothing as it's obvious why your bias (down stream) would drift wildly ... it's a similar situation to the other engineer'ed limiter in this forum that includes an ota ... hint: where luck plays a big, sometimes disastrous, role
QuoteIf you think about the offset I am seeing, the bias point is higher than expected, adding 100 ohms in series with the base of TR6 would actually make it slightly worse in this case since it will make TR6 turn off a tiny bit more. It would also increase the noise floor slightly - this topology is very sensitive to base resistance, I find even 100 ohms is barely acceptable.
I think it's more likely small mismatch in VBE of the LTP transistors. In any case it doesn't matter much
Yes, the offset goes the wrong way for adding a resistor to TR6 - I only eyeballed the asymmetry.  It could be imbalance in the mirror since that also needs to match Vbe's.  A common balancing act is to add emitter resistors to the mirror  (provided they match better than the Vbe's).   Like you say the imbalance doesn't seem to matter, sounds fine.
I always like your designs because you aren't afraid to keep the impedances low to keep the noise down.
jonny.reckless
Quote from: Eb7+9 on June 24, 2020, 05:49:52 PM
I don't know what you mean, can you explain? The bias doesn't drift wildly, it does move a little with input signal level but it's not audible. The Wilson mirror is there for a reason: the performance was inferior without it. You need fairly good static and dynamic current mirroring in this topology to avoid thumps and audible artifacts.
Which one?
11-90-an
#27
Sorry if this is a very idiotic queston but...
Are Vdd and +9v the same in this circuit? If so, then why are there 4 decoupling caps, 2 100nf and 2 100uf? Or can they just be replaced with 1 100nf and 1 100uf to lower part count?   :o
flip flop flip flop flip
antonis
Quote from: 11-90-an on June 25, 2020, 08:02:34 AM
No they don't..!!
(you can realize it either by measurents taken or by VBE drop on TR3/TR4 Emitter follower (Sziklai pair)
11-90-an
#29
Quote from: antonis on June 25, 2020, 08:22:49 AM
No they don't..!!
So do I connect anything to the VDD...?  :icon_question:
Or is it just a label that has no significance on breadboard? (Sorry for my stupidity) :(
antonis
It's never a stupidity matter .. :icon_wink:
You probably don't undestand well overal circuit function..
jonny.reckless
#31
Quote from: 11-90-an on June 25, 2020, 08:27:19 AM
There are no stupid questions, only stupid answers  8)
9V is the supply rail that comes into the pedal from your PSU. This supply powers the side chain transistors TR12 and TR13 and their associated components. Then there is a filter / smoother comprising TR3 and TR4 which generates VDD. VDD is about 0.7V lower than 9V, but has much less noise and ripple on it. VDD is used to power the rest of the circuit which is much more sensitive to noise. When you are playing clean it's not usually a problem but if you put a compressor in front of a drive pedal for example, the noise starts to become really obvious, and I wanted to keep it as quiet as possible, in terms of both hiss and hum. You could certainly build the unit without the extra VDD power supply and it would work but it will be a bit noisier depending on how high quality your power supply is. If you are running from batteries this will likely be fine. I use a Voodoo labs pedal power and that is also pretty clean but some of the cheaper 9V adapters generate a lot of high frequency switching ripple and 120Hz hum on their outputs, sometimes 10 - 20mV or even more which will adversely affect a design like this without extra filtering. Feel free to experiment!
Quote from: jonny.reckless on June 25, 2020, 05:49:15 PM
Sorry to bother you Jonny, but how exactly this transistor pair filters the noise? I'm really curious to learn this!
Eb7+9
#33
Quote from: jonny.reckless on June 24, 2020, 09:42:20 PM
exactly ...
I've got your "Reckless Pair" idea down to 9 transistors
similar to yours, it's exhibiting no static or dynamic level shifting at the output
I'm also playing with scale-able input gain - for gtr/bass headroom
note:
using op-amp buffers gives the signal path a much higher cmrr
(with psu ripple way less of a an issue) and there's less noise overall ...
the ota is just a standard four-device structure ...
achieving close-to-ideal one sided ota performance
btw, where's the half-wave side chain from ? ... I've seen it before
Emitter follower with an R-C filter to the base. Instead of raw supply crap you have filtered supply crap.
An elaboration: the Sziklai pair to allow smaller capacitor (or just because he uses the Sziklai everywhere else).
Also because any stray impedance in the filter will let Vdd bounce with the beat which may add thump. In this form the output impedance is very low.
11-90-an
#35
okk... BB'd the PMC and it works nicely...  :)
(anyone has any chicken pickin riffs?  ::))
niektb
Quote from: rankot on June 25, 2020, 06:18:02 PM
In essence it's a capacitance multiplier! (The capacitance located at the base of the transistor)
11-90-an
Redrew the schematic for people (Like me) who get dizzy with all the intersecting-lines-that-aren't-connected-to each-other...  :icon_cool:
jonny.reckless
Quote from: 11-90-an on June 26, 2020, 10:54:26 AM
Yes, that looks correct to me :)
jonny.reckless
Quote from: 11-90-an on June 26, 2020, 08:13:26 AM
okk... BB'd the PMC and it works nicely... is there a way to make it 'tighter'?  :o
I am not sure what you mean by "tighter" sorry, can you explain?
