Fuzz Face issues: 9v @ Q2, no sound, switch pop....
Started by DJPsychic, August 02, 2020, 02:14:03 PM
DJPsychic
Just finished boxing a Fuzz Face that I've done before, except I added a DC jack and a 1M @ input for switch pop.
I'm getting 9v @ Collector of Q2, no sound, and switch pop. Bypass works.
What is the usual culprit?
Quote from: DJPsychic on August 02, 2020, 02:14:03 PM
The absence of the rest of measurements..!!!  :icon_mrgreen:
+9V on Q2 Collector means Q2 is completely cut-off..!!
Maybe due to open Emitter, maybe due to open Base, maybe due to gremlins..
jimitrader
make sure all grounds are connected good..also look for cold solder joint...check with audio probe and also with mm check where the 9v power stops may be a dead component..star at right where the 9v comes in and follow till it stops?. :icon_cool:
DJPsychic
Sorry just had a chance to check phone.
Thanks for the suggestions. I'll go through it tonight.
everything appears to be grounded correctly but will look at it closer. Just spent half the day wiring it, sick of looking at it! Lol :icon_evil:
DJPsychic
#5
willienillie
#6
Quote from: DJPsychic on August 03, 2020, 03:43:19 PM
The only difference from layout is VOL is grounded on "L2" of Input jack.
Actually L1, ring.  But why?  I mean, it should still work.
Bigger picture, the layout you used appears to be for NPN silicon transistors.  It looks like you used germanium transistors, are they NPN or PNP?
What is your 3rd pot?  Nevermind, I figured that one out.
DJPsychic
Quote from: willienillie on August 03, 2020, 04:14:03 PM
Oh yes sorry, CV7112 NPN
So looking at back of enclosure, Top left is "Fuzz"" pot, top right is my "Bias" (basically Fuller 69 pot at input), and middle pot is "VOL"
Marcos - Munky
Ah crap, I don't like veroboards at all. Can't really understand them, too much for my mind.
But while I don't know if I can really help with your problem, I can do something else:
- the "bottom" trace cut seems to be not really cutting the trace. While the other ones have a nice hole cutting the trace, the bottom one seems to still have a bit of copper at the top part.
- at the bottom of the layout, the 6n8 cap and 1K resistor are shorted. Their both legs are connected together by the copper trace. You have to do a "cut" (a hole, like the other ones you did) between the legs of the cap and between the legs of the resistor.
DJPsychic
#9
Quote from: Marcos - Munky on August 03, 2020, 04:53:40 PM
Oh man I think you're right. I went back in my files and I think I used this layout originally...
It shows I'm missing a cut under the "6n8"
Marcos - Munky
You're missing a cut under the 6n8 cap and also one under the resistor. Or else the resistor won't be doing nothing at all. I don't believe shorting this resistor is enough to fry your transistor by too much voltage on the collector, but still.
DJPsychic
Quote from: Marcos - Munky on August 03, 2020, 05:18:02 PM
I don't think I've ever had a cut under the 1k.
It's hard to read but there's a 10k trim pot between the 1k and Collector of Q2
"T1" & "T3" on my layout represent the legs of the trim pot
DJPsychic
Added the cut under the 6n8 and still getting 9v @ Collector of Q2.
Trim pot has not effect.
Maybe one of the NOS resistors went bad?
Could you plz post a precise schematic of your layout..?? :icon_mrgreen:
Phend
Should have used the point to point method. Sans wood box.
  • SUPPORTER+
When the DIY gets Weird, the Weird turn Pro.
DJPsychic
Quote from: antonis on August 04, 2020, 03:46:09 PM
I do not. Still a noob using "paint by numbers"  ;)
DJPsychic
Quote from: Phend on August 04, 2020, 05:02:12 PM
Not sure I understand? ???
Phend
#17
This is a 1970s Electro Harmonix Muff Fuzz circuit . (Purchased) point to point at its tightest. Even back then the challenge was to get er in the smallest box possible. Note the clean sollldering.
Wood box, well just a wood box enclosure, yer all set with yours.
Anyway sorry for interupting , back to letting the experts help you debug your cool circuit. Nice job. Stay safe.
  • SUPPORTER+
DJPsychic
