How can this be?
Started by Guitarist335, August 18, 2020, 05:28:48 PM
Guitarist335
I have built this circuit a few times, and successfully.
This time around however, i decided to change the op amp and use the 4558D op amp.
While I was building it, I was paranoid about building the voltage divider part of the circuit, and so i tested it with a meter along the way. It was sending the correct voltage.
I built the entire circuit and the meter measurements from the negative terminal of my 9 volt battery, and the various pins, seemed to be okay. (I shorted pin 6 and 7) to disable the second part of the op amp.
But all of a sudden, without my changing anything, all of my measurements from all the pins on the op amp, shot up to over 8 volts. Even Pin 4 , which is suppossed to be ground, is over 8 volts.
How can this be? Even the point of the volktage divider where it should read half the voltage, is over 8 volts. See attached pics (my build, front and back and the schematic i am building from)
P.S. Here is the datasheet for the op amp.  https://components101.com/ics/lm4558-dual-op-amp-pinout-datasheet
I did not know what to do with Pin 5. Was I supposed to send that to ground- is that what could have caused this?
Thanks for your time.
11-90-an
How's your battery?
I think you may have some shorts in your board... try reflowing
flip flop flip flop flip
Sounds like you may have lost your ground connection.
Guitarist335
Thanks guys.  Will check it out
