Out voltages 1=4.98 2=0.9 but erratic 3 -16 were all zero
In voltages 1=4.98 2=2.43 3=0 4=0 5=4.98 6=0.4 7=0 8=0 9-16 all 2.44
I tried new chip sound passes doesnt chorus then slowly dies out
Let's start at the beginning - get the power working. Without the PT2399 in there, you should have:
Pin 1 - 5V, from the regulator. 4.98 looks good to me
Pin 2 - 2.5V reference voltage for the internals. 0.9V is wrong, and suggests to me that the grounding isn't good.
Pin 3 - Ground
Pin 4 - Ground
With the power turned off, you could do a continuity check between your ground points, especially those pins 3 and 4.
Once the power is good, then we can fairly safely put the chip in and see what happens and what voltages we get.
HTH,
Tom
