active bass preamp inspired by a famous one
Started by Gus, September 26, 2020, 08:31:54 AM
Gus
Instead of a IC I used three active devices
It uses more current
The source resistor will need to be adjusted for the JFET used
Cascode first stage with a simple emitter follower EF buffer
The preamp it is based on uses the inverting input for the network. A common source amp is inverting.
Something to get people thinking. I have not built it.
The IC one this was inspired by will be better for battery life and maybe tone
Something a little different inspired
