Author Topic: Dallas Rangemaster: voltage collector  (Read 4066 times)
ricci
Re: Dallas Rangemaster: voltage collector
« Reply #80 on: December 01, 2020, 06:16:07 PM »
With the 33nF cap between E and C I reduce the frying noise that is in the background
Strange way for inreasing Power Supply Rejection Rate .. :icon_eek:
I don't know why this happens but it greatly reduces the background air blow noise by slightly modifying the tone of the guitar but which always remains bright.
percyhornickel
« Reply #81 on: December 01, 2020, 08:54:39 PM »
that tranny is silicon
of course it has less noise.
i had my BD139 range master biased at 8.4V since it sounded the best there, it gave me a punk-rock sound when used in a clean amp and a really tight hard hitting grind when used into a dirty amp, but i biased it really close to gating, just at the brink. so its no problem to bias it anywhere else, just use your ears to where it sounds best!
cheers, Iain
I really would like to hear the RM with this transistor, dont you have any sound on the web or some site?. I just saw the BD139 hfe = 40, perfect for a RM.
« Last Edit: December 01, 2020, 08:56:50 PM by percyhornickel »
willienillie
« Reply #82 on: December 01, 2020, 10:22:42 PM »
Maybe with a 25K pot.
ricci
« Reply #83 on: December 02, 2020, 04:29:47 AM »
Is there a formula to determine which potentiometer to install according to the hfe?
iainpunk
« Reply #84 on: December 02, 2020, 09:09:30 AM »
cheers, Iain
i'm sorry but i don't have that pedal anymore (the transistor is now part of my DIY class A amp), and i don't have sound recordings either. but it wasn't too different from most range masters, just a bit more broken when into a clean amp but in to a driven amp the difference is really small. i recommend replacing the 68k resistor with a 100k or 220k trim pot so you can change the bias to your liking. i believe i used a 47pF capacitor between the collector and base to simulate a germanium's miller capacitance, but that only makes a small difference.
a range master with such a trim pot, and the miller capacitor and transistor in sockets is easy to experiment with, you can just pull out the cap or transistor and change them for other values/types. and the bias trim pot makes it able to accept most transistors with low-ish gain. i strongly recommend making a flexible board with sockets, so you can mix, match and experiment your own perfect sound!
cheers, Iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
iainpunk
« Reply #85 on: December 02, 2020, 09:17:11 AM »
why would that be necessary? especially with a bias trimmer, i don't see the need for a 25k pot, unless you really need that extra gain. the original oc44 transisor is about the same gain and really low leakage (for a germanium). the reason a BD139 is great is the low gain (comparable in range) and relatively high leakage (for a silicon).
cheers, Iain
『snailpilled』
ricci
« Reply #86 on: December 02, 2020, 02:20:45 PM »
After I solve one problem, another one occurs. Could you tell me why, with the RM activated, when I set the guitar pot to zero, I hear a noise similar to that of the air coming out of the tire when I press the valve ?
https://voca.ro/1cnflRU94gh5
willienillie
« Reply #87 on: December 02, 2020, 06:26:24 PM »
I don't know, I got the idea from RG's Austin Treble Blaster paper.
http://www.geofex.com/article_folders/rangemaster/atboost.pdf
Basically, a higher collector resistor.  It worked for me to get a 40ish transistor to bias up well, which wouldn't with a 10k pot.  Maybe the base-to-ground trimmer gets there too, but maybe at a fairly extreme setting.  But either way, I have had better results with hFE around 70, and a 10k pot.
Big Monk
« Reply #88 on: December 02, 2020, 11:24:46 PM »
Personally, I feel the Rangemaster has to be built with a Germanium transistor. Full stop. Ive built plenty of Silicon ones myself and the mojo is in a properly tuned Germanium unit.
We are what we repeatedly do. Excellence, therefore, is not an act, but a habit. Aristotle
"Beneath the bebop moon, I'm howling like a loon, for you..." Marc Bolan
iainpunk
« Reply #89 on: December 03, 2020, 09:17:12 AM »
i think it depends on what you want, if you like a riff-raff punk sound, a Si does the job well,
if you like smooth rock/pop sounds, definitely use Ge.
i think the black sabbath sound is to be discounted since Toni's range master was heavily modded, allegedly using a ''really large'' input cap, nicer resistors and another tranny.
cheers, Iain
『snailpilled』
ricci
« Reply #90 on: December 05, 2020, 03:14:42 PM »
I read on the web that the last noise I described has it in many users and some say that the cause is germanium but it also happens to me with silicon and with any guitar. Some experts at least to understand if I have to live with it ?
Big Monk
« Reply #91 on: December 06, 2020, 07:13:24 PM »
can you describe be again the issues you are having?
ricci
« Reply #92 on: December 07, 2020, 04:33:39 AM »
I am referring to the volume pot of the guitar. As the volume decreases, when I get to position around 3, I start to hear a white noise that gradually increases as I reduce to position 2 and then to 1 to zero. Here the white noise reaches its maximum intensity
Big Monk
« Reply #93 on: December 07, 2020, 08:37:11 AM »
Is this the same hiss you were initially assigning to the transistors in the boost circuit?
ricci
« Reply #94 on: December 07, 2020, 08:48:35 AM »
no, the hiss I said initially is the background white noise that is always present while this white noise, that is accentuated with the closing of the guitar volume potentiometer, I have discovered it only now. Given how the potentiometer works, in my opinion the ground is involved but I don't know  what to do, maybe some electrolytic capacitor placed in some strategic point but I can't be sure and I wouldn't want to do other random tests. Does the same thing happen to you ?
Big Monk
« Reply #95 on: December 07, 2020, 09:51:21 AM »
How confident are you that your guitar wiring and the controls within it are wired correctly?
ricci
« Reply #96 on: December 07, 2020, 11:30:57 AM »
to 1000/100
ricci
« Reply #97 on: December 07, 2020, 12:32:29 PM »
As already mentioned, the problem happens with all my guitars but I begin to think that it is precisely the transistor so much so that in the drawer I found a BD137 that does not produce white noise in the background though at the output I always have the noise in the closing of the volume pot.
ricci
« Reply #98 on: January 23, 2021, 07:09:13 PM »
Finally, I found that the white noise and hum were caused partly by the power supply but mostly because there is also a digital pedal with which it shared mass. When I used two separate power supplies, the noise disappeared. I also tried an AC142K transistor with HFE equal to 138, which turned out to be quite noisy, and in the end I preferred the AC127 because the PNP was really noisy.
