if you want to lower the gain to be about 1/3rd, just swap the collector and emitter,
The reverse gain is usually only 1 to 10. (You can also get problem with the BE junction conducting if the voltage exceeds about 10V.)
that's not what my experience with reverse BJT's is, a BC547 with an Hfe 318 in reverse measured Hfe 93, and a BD139 with gain of 85 measured 32 in reverse. that is in circuit, not in a DMM or component tester.
yes, reverse breakdown is a risk, but not so prevalent in 9V circuits, and enough datasheets list the max reverse BE voltage rating that you can account for that with series diodes/LEDs to lower the potential voltage on that junction
cheers, Iain
