Use of Incandescent lamps in distortion circuits
Started by Vivek, December 05, 2020, 04:26:08 AM
Vivek
Please post links of schematics where small incandescent lamps are used in distortion circuit
Either due to time constants of resistance change with signal envelope
Or Non-linearity of resistance with current
or some other innovative application (Effect On/off indicator does not count :)
Thanks !!!
11-90-an
Quote from: duckduckgoose on December 05, 2020, 07:03:24 AM
i found this on duckduckgo
https://www.youtube.com/watch?v=ET5nrjqLazk
That vid referenced this one...
It uses the bulb as a compressor/limiter... not really a distortion, but it does have a resistance change with signal envelope so I guess it counts... :icon_mrgreen:
flip flop flip flop flip
iainpunk
i used to experiment with a bulb a lot, mainly to pull more current through an opamp at the attack before its reached max heat, this higher current lowers the output voltage of the op amp, and simulates sag, but i couldn't get it to work subtle enough, it was more of a caricature of real sag...
cheers, Iain
cheers
