Author Topic: Meatball, Mutron, Qi-Gon Questions & Brainstorming  (Read 513 times)
auden100
« on: January 07, 2021, 01:52:05 PM »
Iím taking a plunge into the Meatball Envelope Filter. Iíve been collecting ideas and schematics while I wait for parts, and I have a couple of questions in hope of help from you all.
1) In the filter section, there is a 2-pole switch hooked up to change the frequency range of the filters. Normally the caps on those poles would be roughly equal. What happens if you separate the two poles and make two switches or use non-equal values for caps?
2) I was looking through an article on state variable filters, and I read that with the addition of a fourth op amp one can make a notch filter. Iím not familiar with any guitar notch envelope filters. Is it useful? Anyone know a pedal I could look up a sound sample on? Would that work with the three inverting opamps as presented in the original circuit? Or would I need to alter the inverting lineup to compensate?
Filter article:
https://www.electronics-tutorials.ws/filter/state-variable-filter.html?fbclid=IwAR2jg6qlNBrt5HzVjXoqj6zc5fA0aPLHvprkm_sWxvK_M0CksUlLlmEYA10
Meat Sphere version from MusicPCB:
http://www.musicpcb.com/pcbs/meat-sphere-filter
As for mods (Iím planning big and working on perfboard, so I expect some pruning might be wise), Iím shooting for:
- Color Mod: tie legs 2 and 3 together on the color pot.
- Inverting Opamp: add a switchable inverting opamp to filters for inversion compensation.
- Qi-Gon Version: makes several changes, including adding an LFO. This is a low priority mod for me.
- Expression Pedal Jack
- Replacing two rotary switches with a on-off-on SPDT (Bandwidth) and a DPDT (Up/Down).
If anyone has extra mods to recommend or input on what Iíve listed, lay Ďem on me.
Illustrator by day. Pedal tinkerer by night.
www.artstation.com/auden
iainpunk
Re: Meatball, Mutron, Qi-Gon Questions & Brainstorming
« Reply #1 on: January 07, 2021, 02:38:45 PM »
1)
you lower the Q factor of the filter, this means less available resonance and flatter slopes (Q factor stands for Quality factor)
2)
famous pedals use notches that are frequency modulated up and down by an LFO, they are called Phases. the Phase 45 is a single, very narrow notch, the phase 90 has two notches that are about two an a half octave apart.
i wouldn't worry about phase flipping, since the filters will be changing the phase anyways, DC phase becomes irrelevant for the most part.
cheers, Iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail
snail man [x11]
snail man is fuccing real
auden100
« Reply #2 on: January 07, 2021, 02:51:57 PM »
Thanks, Iainpunk. Very clear. I knew phasers did that, but I had assumed they all created a whole array of notches, not just one as in the P45.
Conclusion:
- Keep the cap switching as is. (100% answered. Cheers)
- Notch envelope filter is conceivably worthwhile. Perhaps more so with the Qi-Gon additions.
- Confusion on the inverting opamp. I have read other modders state the inverting opamp mod evens out some volume discrepancies between the filters as they blend into the original signal. You are saying the it wonít make a difference, or perhaps it wasnít clear the filtered signals would be blended into the original.
idy
« Reply #3 on: January 07, 2021, 04:15:39 PM »
If you re-read the thread,  people are saying that one of the positions, LP is inverted in phase and when blended with the clean signal some find it weak, it is canceling out the dry. (I only use the band pass so it doesn't "phase" me...)
Looking at the schematic, and then reading a little about state variable filters, you will find that both HP and LP are inverted, so you would maybe try inverting both of them. The fact that the people talking about this don't notice that suggests maybe that people are "spit-balling" and not responding to a real problem. As the more knowledgeable  poster above pointed out the filter is really changing phase all over and so the cancellation is not as obvious (or undesirable) as you might fear...maybe. But a phase toggle makes sense, I would be curious to hear bandpass inverted to make a notch when mixed back in. So one op-amp with a toggle after the mode selector.
To me the four positions for filter range seem like: medium, high, very high, ridiculously high. An experimenter might try different values for those caps, but probably keep the pairs the same, because the beauty of the filter is that it can get focused. To make it less intense you can: decrease sensitivity, or intensity, or resonance, or blend. Or use the 'bandwidth' at 1/2. Heck even using slower attack makes it less extreme. But it you like experimenting it would not be hard to have the caps on the rotary or a daughter board and socket them.
By far my favorite addition is to use a buffer and a switch to select either pre or post effects loop for the dry side of the blend. It seems a little insipid to mix a wild fuzz auto-wah sound with a clean guitar, but mixing it with original fuzz really makes it "pop" and come alive. The post loop side needs the buffer.
iainpunk
« Reply #4 on: January 07, 2021, 05:16:41 PM »
yes. this
i'd add this to the output of the filter, before mixing with the clean again.
there are 3 fx loop points id considder, before the filter, after the filter, the clean signal (parallel to the filter) but keep in mind that most filters work best with a clean signal's envelope and a distorted signal might keep the filter at the same place, instead of sweeping.
cheers, Iain
snail man [x11]
« Reply #5 on: January 07, 2021, 05:20:30 PM »
One other reason that you might not notice a highpass filter being out of phase so much is that most of the fundamental will be removed, so the place where it would be most obvious has also been removed. You can't have a sound that sounds a bit thin if it's already a bit thin!
auden100
« Reply #6 on: January 08, 2021, 09:30:23 AM »
@Iain, Thanks for the idea. Iíll have to compare the separate inverter addition youíve described with the Qi-Gon variation that just changes the first opamp to non-inverting. From what Electric Druid is saying, it might be useful enough, and it would spare a couple opamps to still get a notch filter from the summed low and high passes and a buffer on the post-fx mix.
@idy, Iíll probably socket the caps or use a 6-pole switch for a couple extra options. Also, the post-fx blend with buffer seems like a sharp addition.
@ElectricDruid, tastes pretty truthy to me. ;)  But actually, that some people liked an inverter on both filters and some only inverted the low-pass did confuse me a bit. Thatís good insight. Once this thing is breadboarded, Iíll know for certain.
auden100
« Reply #7 on: January 20, 2021, 03:44:45 PM »
Just wanted to put a quick note in here for posterity.
COLOUR MOD MOD
There's been some interest in the Colour mod, tying together a couple legs of the pot. I've got a version of the Meatball on my breadboard (can't get my MC1458 to work, so I'm using the Qi-Gon Y-trigger with a TL072). It seems like the Colour mod works fine, but I prefer instead no mod and using an anti-log C pot. I happened to have one, and it made a very handy difference in finding the right balance in resonance.
The volume problems with the inverted filter signal is confirmed. As expected, the volume decreases as the blend knob approaches halfway point and is normal volume at either extreme. I think it'll be worthwhile to implement the inverting buffer.
One characteristic I'm trying to compensate for the the curve of the filter movement on decay. It's kind of like a logarithmic downward slope. Starts slow and accelerates down. Playing with the decay control slows the slow part, but doesn't affect the fast descent much. I'm not remotely knowledgeable enough to do more than trade put a few components and hope. So it'll probably just stay that way. It's all still quite useful as is.
The Qi-Gon Y-trigger has worked great in lew of having a working alternative. The Sweep control plays an interesting game with the Intensity control, and it does take a bit to find the pocket. But if you don't like fiddling with knobs, then you shouldn't be building one of these anyway.
idy
« Reply #8 on: January 20, 2021, 05:53:24 PM »
If you go back to the "building the meatball" thread some bright people explained why the 1458 is such a dicey choice for the trigger, and the fix: adding just shy of 2v bias to its input.
The mutron is bipolar power so bias to ground is okay, but the meatball is single side power but keeps the ground....and the 1458 doesn't play nice close to the - rail.
Without that I found I needed a booster on the guitar to make it trigger easily.
auden100
« Reply #9 on: January 21, 2021, 04:11:33 AM »
Thanks for the heads up. Iíd looked a bit through that thread, but youíve clued me in to your nice little summary post. Very helpful.
Post here: https://www.diystompboxes.com/smfforum/index.php?topic=92894.msg1182648#msg1182648
I like that the Qi-Gon has the LFO option integrated. The pedal is so big already that not having need of an additional auto-wah style effect might be helpful. The prime disadvantage IMHO being that given the high interactivity of controls and fine range of favorable sounds, any on-stage fiddling with this effect is not ideal. So many options. Iíll keep fiddling.
auden100
« Reply #10 on: January 27, 2021, 02:06:06 PM »
Qi-Gon Schematic
I received permission to repost this schematic today. So here it is. :D
Two questions arose. I have it built without the LFO. Everything seems to work fine. But some characteristics appeared that Iím not sure if itís typical or something I need to troubleshoot more.
- I get light distortion from the filter signal. Not from the clean signal. Is that typical? Iím using store-bought vactrols. The indicator LED flashes at the rate of the distortion. Iím not sure what is causing this. Any ideas? Iíve had the same distortion while using both TL072 and a 4558 on the envelope follower, and it seems like thereís some kind of rippling happening in the LEDs that I canít contain.
- The Moog mod doesnít make a positive difference. I tried implementing the Moog mod with the Qi-Gonís non-inverting lowpass filter. It just doesnít sound like it works the same as with the Meatball. It seems to just make the filter less pronounced. Does that seem right? The envelope section works fine with both the original and Qi-Gon versions of the filter. But the moog mod isnít quite amazing enough to warrant the added re-inverting stage that I liked on the Meatball.
MOD ALERT!
I have one tiny mod to the Qi-Gon that was nice. The Sweep knob is pretty cool. As originally described, when it is at the centerpoint, there should be no sweep at all in the LEDs. That was true with the 4558, but not the TL072. I found that I just had to put a trimmer on one side of the Sweep pot, and then I could adjust the location non-sweeping point on the pot accordingly.
