Thanks all!
I started with the suggestion of Antonis.
ID = IDss(1-VGs/Vp)^2 Notes
Idss 0,11mA 0,2-1mA (datasheet, I measured at 9V)
VGs 0,106 V Measurement Q1
VP 0,54 V? Average value for J201's (diystompboxes thread)
VDD 19,85V input voltage
Vsource 0,108V
=> ID:
0,071053361
=> Rdrain:
138,9237595 (k?) 62k in this slot gives me approx half voltage
It seems the jfet measures a bit low on Idss. I measured at 9V with only the multimeter (suggestion i found by someone).
VP is uncertain, some average value for J201's that I found on this site. All other measurements are with the
input voltage of ~19,85V.
I get the right order of estimate (139k compared to 62k in reality). What do you think?
As a side note: from your comments I gather that if I cannot change Rsource, the best option is just to set Rdrain for half supply voltage. This is my only option for the 7thheaven, as only the Rdrain is a trimmer. However, this teaches me a lot for the next step that I would like to undertake: changing tube amp schems to fet stompboxes (starting with a simple supro). I am very grateful for all your comments.
I need some more time to reply to the other answers. Those will be next.
**added later**
Come to think of it, I probably should measure idss at the input voltage rather than 9v. If the relationship is linear, double Idss will give me half the Rdrain, which is approximately equal to the 62k I used
