I'm putting together a EQD Life Pedal clone on a breadboard. I've got the whole thing wired up and it works great.
From what I understand, the stock boost circuit is based on EQD's Black Eye boost.
I have the stock boost wired up, but I decided I also wanted to hear what a SHO boost circuit would be like in that position.
I've tested (by ear) both boost circuits on their own and they seem to give pretty similar volume increase, the Black Eye circuit probably a bit more.
I used the schematic for the Life Pedal for the Black Eye boost part. But for the SHO circuit, I just built from the SHO schematic and connected it in. Maybe there's something that needs to be changed when it's placed like this in the Life Pedal?
The thing I'm noticing is that once I stick the circuit at the end of the Life Pedal, the stock boost circuit still gives a massive amount of volume increase as I turn the knob up.
The SHO does give a volume increase as the knob is turned, but it also seems to be adding more hair to the signal. Not what I would have expected, and I didn't notice it when the SHO was on its own.
Is there a reason this would be the case?
