The idea for this project sparked in this thread:
https://www.diystompboxes.com/smfforum/index.php?topic=126087.0 In short words, what it does is instead of having to write the new hex file to the onboard EEPROM everytime something has changed in the code you can just plug in a remote emulator/programmer having the following features:
- web interface for uploading the hex files and switching between the patches with 3MB disk space
- for even faster upload - access through an FTP server
- clicking on "Enable" parses the hex file and makes it available for the FV-1
- once the hex enabled, clicking on any of the 8 buttons will upload corresponding patch to the FV-1
- if the work on the code is done you can burn that firmware to the EEPROM
- as final test you can enable the onboard EEPROM to test if everything works fine
- works up to 44.1kHz sample rate (i2c clock depends on the sample rate).
Schematic, code and instructions are on github:
https://github.com/hexeguitar/FV-1_devRemoteProject is written using Platformio + VScode.
