Author Topic: Rangemaster PNP 9v wiring (LED + True bypass)  (Read 203 times)
rangermaster
« on: January 24, 2021, 03:05:46 AM »
Hi there.
I want to build a Rangemaster clone but i'm a little confused by the -/+ wiring it needs.
I want to use the rangemaster on my pedalboard and use the power supply that is feeding all my others (Center negative)
I have a few NOS OC44 transistors that i will use for this build so i would like to keep it a PNP circuit.
i found this schematic from Paul in the Lab:
should this work with the power supply and PNP circuit ?
Also.. i would like to use a 3dpt footswitch for true bypass and a led..
can i use this? :
Thanks for the help.
(Sorry if the pictures are too big.. don't know how to fix that)
« Last Edit: January 24, 2021, 03:08:25 AM by rangermaster »
rangermaster
Re: Rangemaster PNP 9v wiring (LED + True bypass)
« Reply #1 on: January 24, 2021, 04:36:26 AM »
I talked to Paul. And he already helped a lot with the wiring.
« Last Edit: January 24, 2021, 07:44:52 AM by rangermaster »
