Hi everybody!
I've been building my own Revv G4 clone for a while. I did my own pcb by milling it with dremel on a board. I transfered the pcb image on the board from
http://effectslayouts.blogspot.com/2019/11/revv-g4.html and it should be a verified schematic/layout.
For offboard wiring I used the same site,
http://effectslayouts.blogspot.com/p/general-layout-notes.htmlI use an old wall wart (~10V) as a psu that I have hardwired to the board temporarily. I have replaced some resistors to the nearest values that I had in my box, but the value differences are negligible. I also replaced the 1n5817 diode with a 1n5822, which I think is different on voltage/amp rating only? Correct me if I'm wrong! All the caps are the correct value, IC's are the TL074&TL072, potentiometers are the correct value and everything should be working as planned... but no! It's not working very well at all.
When the pedal is off I can't get any sound at all. So that leads me to believe there is something wrong with the switch maybe? I've wired it according to the picture on the site I've linked above. When I push the pedal on the led lights up as it should and I do get some sound (soundclip link somewhere below!), but it sounds like farting with an octaver on. Which isn't quite what I was looking for when I started building this pedal.
I have gone through all the traces for bad solderjoints and solder bridges, but couldn't find anything at all. The voltages across the IC's are as follows:
TL074:
1: 7,3V
2: 7,3V
3: 7,3V
4: 14,7V
5: 7V
6: 7,3V
7: 7,3V
8: 7,3V
9: 7,3V
10: 7,3V
11: 0V
12: 7,3V
13: 7,15V
14: 13,7V
TL072:
1: 7,3V
2: 7,3V
3: 7V
4: 0V
5: 7,25V
6: 7,3V
7: 7,15V
8: 14,5V
I have no idea if these voltages are even near the ones that should be...
Here's a low quality video/soundclip of the pedal. Sorry for the messy table and the wiring is a temporary one. I'm going to tidy it up once I have my enclosure ready to go. As you can see on the video the volume works, the eq pots work fine, but when I turn the gain pot the gain does ramp up, but so does the interference and there's very little sound from the guitar. Also there's this octaver pedal style sound in there... When playing it's like adding a lower octave in the mix!
https://www.youtube.com/watch?v=0TdfCah3fcc
