DIYstompboxes.com
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
|HOME|
|DIY FAQ|
|GEO FAQ|
|Debugging Page|
|Links|
|Schematics|
|Wiki|
|Layouts Gallery|
|STORE|
|AMPAGE|
|GEOFEX|
|AMZ|
Home
Help
Login
Register
DIYstompboxes.com
DIY Stompboxes
Building your own stompbox
Changing gain pot value in Boss SD-1 mod
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Changing gain pot value in Boss SD-1 mod (Read 222 times)
SpikeVelvet
member
Total likes: 2
on:
January 24, 2021, 11:04:57 AM »
I am not sure I really understand how pot value works for the gain control in a circuit. I'm hoping somebody can explain like I am 5.
I modified an SD-1 and changed R6/C3 to give the pedal more gain. It still has the stock 1M pot. I have all the gain I need at about 12 o'clock. Am I correct in assuming that if I change out the pot to a 500k it will have the same amount of gain at max but a more useful and precise sweep of the pot?
Also, isn't there a way to strap a 1M resistor across the terminal to have the pot behave like a 500k?
Thanks,
Kevin
Logged
bartimaeus
Great Contributor!
Total likes: 33
Re: Changing gain pot value in Boss SD-1 mod
Reply #1 on:
January 24, 2021, 11:45:50 AM »
why not just tweak R6/C3 to give you the amount of gain you want at max?
Logged
POTL
Great Contributor!
Total likes: 30
Reply #2 on:
January 24, 2021, 11:52:00 AM »
the gain will decrease by 2 times. if you are not satisfied with the smoothness of the adjustment, check what is the characteristic of the potentiometer, it is indicated by letters, usually A, B, C, W. you need a potentiometer with the letter A
Logged
antonis
Awesome!
Total likes: 1745
Antonis D. - Greece
Reply #3 on:
January 24, 2021, 11:58:56 AM »
Quote from: bartimaeus on January 24, 2021, 11:45:50 AM
That..!!
(more cheap than preplacing pot mod..)
Logged
"I don't mind being taught all the time but I do mind a lot getting old" Antonis the Thessalonian..
iainpunk
Awesome!
Total likes: 1196
Iain Tonny Schmaloer from Arnhem, NL
Reply #4 on:
January 24, 2021, 04:33:19 PM »
i'm 95% sure its a log pot, so in the middle isn't actually 50% resistance, more in the neighborhood of 35% resistance. if you are on a spending spree already, i suggest getting a TRIM pot of 2M and put it parallel to the gain pot, set the outside knob to max and turn down the trimmer resistance until you have the desired max gain.
cheers, Iain
edit: 1300th post
Logged
(1 person liked this)
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
Print
Pages: [
1
Go Up
« previous
next »
DIYstompboxes.com
DIY Stompboxes
