I am troubleshooting a friends' DS-1, pre-1994 I believe as it has the BA728N Op-Amp. Upon first opening, I found the exploded D1 1N4004 power supply diode and noticed burn marks on both terminals of it on the solder side of the business. So, I took to troubleshooting with a probe and voltmeter and am hoping someone can help me make sense of the readings and confirm my thoughts on what to replace. I know these pedals aren't worth much but I'm looking at this as a learning opportunity to troubleshoot and hopefully fix a pedal that I didn't build.
* I only had a 1N4001 diode to replace the 1N4004 but it seems like from other DS-1 threads that this is not an issue.
The pedal's LED comes on and clean sound is passed in bypass. No sound at all when the effect is engaged.
Battery voltage outside of pedal is 9.43v
Voltage at battery snap when plugged in 9.41v (9.37 by the time I finished testing voltages)
IC1 (BA728N in-line)
P1 0
P2 0
P3 .04
P4 0
P5 0
P6 0
P7 0
P8 9.40
Q1
C = 9.39
B = .01
E =1.75
Q2
C= 1.20
B= .03
E= .01
Q3
C= 9.38
B= .01w
E= .92
Q4
C= .05
B= 0
E= 0
Q5
C= .02
B= 0
E= 0
Q6
C= 0
B= .27
E= .27
Q7
C= 0
B= .28
E= .28
Q8
C= 0
B= .27
E= .27
D1
A (anode, the non-band end) = 0
K (cathode, the banded end) = 9.37
D2
A = 4.36
K = 9.36
D3 (can't find it - maybe the LED indicator?)
A =
K =
D4
A = 1.08
K = .95
D5
A = 1.08
K = .95
D6
A = 0
K = 0
D7
A = 0
K = 0
D8
A = 0
K = .04
Since I dont know the exact variation of the schematic to follow, here are the places I HAVE signal with the audio probe:
Q1 E+B
Q2 E,C,B
Q7 C faintly
Q8 E
IC Pin 1, 2 and 5 faintly, 3.
R1
R2
R3
R9
R10
One side of R4 and R5
J1
J2
Q8 all pins but collector less
Anode side of D6 and D7
Picture of the board below:
