Something in your LFO is not working properly. You should be getting a varying voltage on either Pin 1 or Pin 7 (excuse me as I do not have access to the schematic at this time)
Your Pin 7 seems very high at 8.14V.
When checking the LFO, recommend you set the Speed pot to mid-range otherwise the voltage readings will be hard to track on a meter.
Check for component values in the LFO circuit, capacitor vales and orientation, solder bridges, etc.
EDIT: Pin 5 of IC3 should be Vref. About 1/2 of your input voltage. Yours is at 7.6??
