Hi folks,
I posted a while ago looking for some assistance with my first attempt at a vero layout (thread is
HERE). It took me a bit of time to build the circuit and an even longer time to box it up. I noticed some small issues that I thought I'd taken care of through swapping out transistors but after spending a bit more time with it, those issues seem to be persisting. I'm hoping you smart kind folks might be able to help me track down what's going on.
So, a quick recap...
Here's the original schematic:
(*note: there's a backwards capacitor)
Here's the layout I landed on with the forum's help:
Build pic #1
Build pic #2
I've checked pretty closely for solder bridges, and it seems clean enough. Boxing the pedal didn't alleviate any of the issues (i thought it might be RF/etc, which usually go away in an enclosure).
It's currently built up with 2N2222a in Q1 and Q2 and a 2N5088 in Q3.
Voltages as follow:
Q1
C - 6.22
B - 1.44
E - 0.95
Q2
C - 6.22
B - 0.95
E - 0.39
Q3
C - 2.69
B - 0.53
E - 0.00
And here's what's happening as best as I can describe it...
With the fuzz pot past about 2 or 3:00 there's a high frequency whine, right around 13K. This happens without the guitar being strummed. As I back off the fuzz from full CW to about 12/1:00, that whine increases in frequency until it disappears (I assume it moves out of audible range?).
When I strum the guitar with the pedal engaged, I can see a spike around 13K happening, and there's a weird, persistent kind of oscillation happening. The fuzz itself isn't great sounding, and I assume not what it's 'supposed' to sound like based on my experience with other tone benders. It sounds (and this is I believe a very technical term) kinda farty and doesn't have the amount of saturation I'd expect from a TB MKIII derivative, especially one from God City.
The transistor leads aren't trimmed, the wires to the pots are longer than they need to be, and I'm sure running the power and input next to each other is a bad move; that said, is there anything jumping out in the schematic/layout/my build that could be exacerbating this sort of thing? Any help would be greatly appreciated. Thanks y'all!
