Hi, I've been working on converting the preamp and EQ sections of my Univox U1226 into a pedal form. I've worked out most of the kinks and I love the way it sounds, but I'm still running into a few issues.
1. The biggest issue right now is that channel 1 (Q1) has a very annoying hiss. I could manage if it were subtle, but it's pretty prominent. The strange thing is that it only appears on the 1st channel, not the second. I also tried rebuilding the 1st channel only with new parts and a couple value changes, but the hiss is still there on the 2nd build. As the 2 channels are identical apart from values, and the hiss is present in two different builds, I have to assume the noise has something to do with the PCB layout. I also tried flipping the power filtering cap (which is near Q1) to the other side of the board, and it didn't make much of a change.
The hiss starts directly at the drain of Q1. Turning RV1 doesn't change the hiss until the last ~10% where it suddenly turns down to silence. The hiss does not appear on the gate or source of Q1.
2. RV3 & RV5 are almost useless. If I audio probe the center of each knob I can hear that they are lowering the volume of certain bands, but when I listen through the output they don't seem to make a change. RV4 has a very strong effect on the signal though, cutting most of the bass and lower mids.
Here are shots of the PCB layout:
