Looking at their schematic:
https://pcbguitarmania.com/wp-content/uploads/2018/05/Electric-Lover-Schematic.pdfI would say R10 is completely unnecessary and is what is stopping you from setting the bias any higher.
I would short out R10 on the back of the board (stick a wire between its pins).
There is only a small range of bias voltages that will work. That is the same for any BBD. Too low or too high bias and the BBD will not pass any signal at all. That's why I like multi-turn (precision) trim pots. One way to set bias it is to find the 2 bias voltages (high and low) where the BBD starts to distort or stop the signal going through, and then set the bias voltage half way between those levels.
R30 of 15k is a design error in my opinion, which was made in the original Madbean Current Lover from which this is copied.
If you look at the original 9V EM circuit (
http://www.metzgerralf.de/elekt/stomp/mistress/images/1981-electric-mistress-v6-schematic.gif) you will see they used 39k connected to the range pot, not 15k.
The reason Madbean lowered R30 was to try and give the pedal a bigger sweep than the original. Lowering it to 15k can work OK so long as the pedal supply voltage is 15V. The problem is that at 9V supply, that attempt at a bigger sweep can end up setting too low a control voltage at pin 2 of the LM311 (part of the VCO) and the VCO can then freeze because it can only go so fast. The end result is a nasty drop out at the top of the BBD sweep. This has been reported here before for the current lover at 9V. If you get a dropout in your sweep, you should replace R30 with 39k so it is like the original 9V EM.
The 22pF clock cap is not an ideal choice and arises from a too simplistic understanding of how this VCO works.
The original 9V EM used a 47pF,and the thinking was that to double the clock speed (as needed by 3x07 chip) the cap needed to be made about half as small (i.e. 22pF). That can work, but the problem with that approach is that you get a non-linearity in the top end of the sweep due to diode reverse current charging up the cap when the discharge diode switches off. All analysed and explained on the EM3207 thread. So I would personally recommend using 47pF like the original too and just twiddle the clock trimmer to give the VCO double the speed of the original 9V EM..
