if you are going on a next build, can i suggest the Harmoinic Instant Coffee, its not ''final'' yet
i posted an Introduction on the other HP thread going on, i encourage you experiment with the resistor values, the capacitor values, the transistors and the diodes.
at this point i have a BC516 as the PNP, paired with a BYX10 diode, and a reverse Beta 2n2222 and a red LED as the NPN side, both with 39k resistors.
with reverse Beta, i essentially mean that i flipped the C and E of the transistor, it still works, but is less linear and the gain of the trasistor is way lower, heavily misbiassing the 2nd gain stage
some ou you might already have read my recent posts and schematics, but i havent seen this thread before, and it seems a good place to post the schematic and name explain:
the 39k resistors are just place holders, if you decide on building it, i recommend experimenting on breadboard beforehand to find the resistors that match your transistors and diodes best.
the 4n7 was initially selected because its the value i have most of, about 60% of all my caps are 4n7, but in lots of diffetent materials and packages, i tried smaller and larger caps, but i keep coming back to the 4n7, it just sounds the best to my ears.
i have also put my NPN transistor in reverse Beta, that gives a really nasty, nasal, noisy tone
i called it the Harmonic Instant Coffee
percolator coffee is nice, high quality, fine tuned by the masters of coffee making and soft in aroma's.
instant coffee is mediocre at best, poor quality, the cheapest beans are used and can be really harsh tasting.
Harmonic Percolator is nice, high quality, fine tuned by the masters of pedal building and is soft in tone.
Harmonic Instant coffee is NOT NICE, simplistic, cheapest parts are great for it, and can be really harsh sounding.
cheers, Iain
cheers
