Author Topic: Big Muff Pi Build (Green Russian) - Troubleshooting - No Sound  (Read 301 times)
ericlaw02
« on: January 31, 2021, 04:22:15 AM »
Hi, noob here, I built a Green Russian Big Muff Pi, and I get no sound at all with the effect on (only bypass works).
Built with the layout from http://effectslayouts.blogspot.com/2016/05/electro-harmonix-big-muff-1590a.html, which corresponds to the Kit Rae schematic here (http://www.bigmuffpage.com/Big_Muff_Pi_versions_schematics_part3.html).
So far I can see the transistor voltages are completely messed up, but I have no idea why it's that way (no electronics background, only know how to solder :icon_redface:):
Power In: 9.13V
Q1: C=6.96V, B=7.7V, E=6.96V
Q2: C=0.87V, B=0.87V, E=0.26V
Q3: C=0.88V, B=0.87V, E=0.26V
Q4: C=0.88V, B=0.87V, E=0.26V
D1: A=0.63V, K=0.88V
D2: A=0.88V, K=0.63V
D3: A=0.62V, K=0.88V
D4: A=0.88V, K=0.62V
Reference transistor voltage for reference: (Q1, Q2, Q3, Q4 order in reverse versus compared to Kit Rae schematic)
http://www.generalguitargadgets.com/pdf/ggg_bmp_instruct.pdf
I've gone through the board with a light and I couldn't find any bridges, tried wiggling everything for cold solder joints and still no dice.
antonis
Re: Big Muff Pi Build (Green Russian) - Troubleshooting - No Sound
« Reply #1 on: January 31, 2021, 06:52:16 AM »
Could you post some photos of your build..??
(both items and soldering PCB side..)
iainpunk
« Reply #2 on: January 31, 2021, 08:41:42 AM »
i have a strong suspicion that R10 R11 and R18 are the wrong values.
we need to see the pictures of the board to be sure tho
cheers, Iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
ericlaw02
« Reply #3 on: February 02, 2021, 12:34:32 PM »
Hi, thank you both for your help!
Finally got to the taking the photos:
Component side: https://i.imgur.com/fLs5fir.jpg
Component side (with light underneath): https://i.imgur.com/KiuHRjz.jpg
Trace side: https://i.imgur.com/u9pRRSw.jpg
In-circuit resistance:
R10: 377 ohm
R11: 10.4k ohm
R18: 10.8k ohm
EDIT: Supplemented photo for the resistor hidden between the 103J & the transistor on the top left corner: https://i.imgur.com/u34Ozaw.jpg
EDIT2: Also supplemented mapping between component values and the schematic I did for debugging purposes: https://i.imgur.com/ZHmAtvR.jpg.
Also realized the photo doesn't show the transistor types, they are all 2N5088s.
« Last Edit: February 02, 2021, 12:46:23 PM by ericlaw02 »
antonis
« Reply #4 on: February 02, 2021, 01:19:18 PM »
Don't get me wrong but that's unacceptable both for solder joints and tracks/pads etching..
Keeb
« Reply #5 on: February 02, 2021, 01:45:31 PM »
So it seems you have a solder bridge here
https://imgur.com/a/IrTddcS
There might be more but it's difficult to make sure from your photos. I would suggest audio probe or going over the pcb and checking continuity along the traces (and their neighbors!) to find any bridges/open tracks.
