Author Topic: Aion FX Luna Spacing Control  (Read 234 times)
Elvis Cocho
« on: January 31, 2021, 03:46:10 PM »
Hello. I just built an Aion FX Luna Tremolo (Tremulus Lune clone). The build went off without any problems. I just wanted to see if someone could explain what the spacing control does; I’ve read a couple or so explanations but none that make intuitive sense to me.
I’ve read that it doesn’t change the waveform but that changes the spacing between waves. That sounds to me like it’s slowing or speeding up the frequency of the lfo. But that actually sounds more like a rate control.
Does anyone have any insight to this control? Also, what is the setting up that would be considered “normal”? I.e. as though the spacing control wasn’t there?
antonis
Re: Aion FX Luna Spacing Control
« Reply #1 on: January 31, 2021, 04:51:24 PM »
From what I can see in various schematics, it alters both LFO and Buffer bias..
(asymmetrical amplitude waveform..)
Sorry but I can't translate it into "audio" result..
As for "normal" position, it should be considered 12 o'clock setting..
(250k +220k = 470k hence a 4.5V mid-point voltage divider..)
« Last Edit: January 31, 2021, 04:53:41 PM by antonis »
iainpunk
« Reply #2 on: January 31, 2021, 04:52:28 PM »
the spacing control determines the DC offset of the LFO, having this higher sends a tad more current to the LED which in turn makes the LDR's resistance lower and the output volume higher. the LFO's actual wave shape isn't affected, but the effect on the volume is changed, so the perceived wave shape is changed (the on/off time is changed while the frequency stays the same)
cheers, Iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
nocentelli
« Reply #3 on: January 31, 2021, 05:06:20 PM »
https://mimmotronics.com/blog/talk-theory-to-me/tttm4/
detailed discussion of the tremulus lune circuit including section on the spacing control
Quote from: kaycee
squeeze on the back and never open it up again
Elvis Cocho
« Reply #4 on: February 01, 2021, 11:45:12 AM »
Thank you so much for the info! Very helpful
