Author Topic: Troubleshooting Aion Azimuth  (Read 547 times)
sabbathfan0220
« on: January 31, 2021, 06:18:05 PM »
Hello all, I'm new to this forum and a few months into pedal building overall (not a total rookie but not a seasoned pro).
This is my first Aion project and I'm having some sort of grounding issue I think. The project is the Azimuth: https://aionfx.com/project/azimuth-legacy/
Everything is soldered except the ground wires in black. I clipped them in place to make sure it worked before the final solder joint but I'm not getting power (LED won't light). If I twist the grounds together as pictured and do not ground it to the jack, the LED will light, but I can't get sound through it when plugged in.
I confirmed the leads on the DC jack are connected properly: red goes to the outside and black goes to the center for standard center negative hookup.
Hopefully something easy that I'm missing here? Thanks everyone.
Aph
Re: Troubleshooting Aion Azimuth
« Reply #1 on: January 31, 2021, 10:08:20 PM »
Is that a metal sleeved power jack?
« Reply #2 on: January 31, 2021, 10:59:08 PM »
I don't see a black on either jack's sleeve terminal, nor to anywhere on the metal case. That might be bad for signal.
sabbathfan0220
« Reply #3 on: February 01, 2021, 12:51:49 AM »
Yes, metal sleeve power jack.
The black wire comes off the left side of the power jack and goes to ground.
11-90-an
« Reply #4 on: February 01, 2021, 03:11:47 AM »
If you're using a metal sleeve power jack, and a center negative psu, you are essentially shorting +9v to GND... i recommend you change that...
P.S. Welcome to the forum... :icon_biggrin:
flip flop flip flop flip
« Reply #5 on: February 01, 2021, 03:34:40 AM »
You can quickly check this by measuring the "9V" voltage where it enters the PCB.
And welcome.  :)
iainpunk
« Reply #6 on: February 01, 2021, 09:33:46 AM »
some electrical tape can isolate the plug form the case, this would be a good temporary fix until you have a plastic sleeved power jack to install
cheers, Iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
« Reply #7 on: February 01, 2021, 09:34:35 AM »
but, as PRR says, you still need a wire [preferrerably a wire on each jack, nevermind what the build docs say about case groundings] between circuit ground and the jacks sleeves. it doesn't matter what colour the wire is.
and also welcome.
"I think we're done here."
sabbathfan0220
« Reply #8 on: February 01, 2021, 09:35:55 AM »
Thanks guys! This is my first time using a metal DC jack. Is there any way to correct this (insulating it somehow) or should I just swap for a plastic jack?
EDIT: Just saw the post by iainpunk. Is there a more permanent solution, or is swapping for plastic the best way to go?
« Last Edit: February 01, 2021, 09:38:33 AM by sabbathfan0220 »
Aph
« Reply #9 on: February 01, 2021, 11:05:21 AM »
Try taking the power jack out of the case (still wired up), isolate it from the box, etc.,  and try the pedal... if it works, you’re good to go... and then YES, replace the jack with a plastic one.
iainpunk
« Reply #10 on: February 01, 2021, 02:56:02 PM »
maybe heat shrink wrap the jack, install it and then heat it and trim the edges, i do this often with output jacks, so only one jack is connected to the enclosure.
cheers, Iain
『snailpilled』
sabbathfan0220
« Reply #11 on: February 01, 2021, 02:59:09 PM »
It worked and it sounds fantastic! I really appreciate the help guys.
I have to ask, why would they make DC jacks that aren't insulated? I can't imagine how these are supposed to be used...
antonis
« Reply #12 on: February 01, 2021, 03:07:34 PM »
On any center positive PSU with grounded chassis.. :icon_wink:
(almost everything except for pedals..)
Marcos - Munky
« Reply #13 on: February 01, 2021, 04:05:04 PM »
As pointed by Antonis, almost everything uses positive center power supplies. Which makes so much sense when you think on a metal dc jack. The jack is in contact with the enclosure, and the enclosure is grounded, so the center have to be positive.
But, for some reason, somebody had the idea to reverse this for pedal power supplies, using a negative center. Since the enclosure is connected to ground, now an insulated jack is required. People got used to this, and then this became how the dc jacks should be wired for guitar pedals.
Of course, this led to loads of pedals that got damaged because people used power supplies on their pedals without checking the polarity.
Aph
« Reply #14 on: February 01, 2021, 06:20:24 PM »
It actually has to do with backwards compatibility when using a battery in guitar pedals.
Marcos - Munky
« Reply #15 on: February 01, 2021, 06:54:52 PM »
For positive ground circuits? That makes sense.
DIY Bass
« Reply #16 on: February 02, 2021, 05:39:01 AM »
I always assumed that it was so the switch on a switched jack could be used to switch out the battery when a power supply is plugged in.
Aph
« Reply #17 on: February 02, 2021, 11:43:22 AM »
Yeah, it's a combination of the switched power jack and the fact that some pedals use a stereo jack (usually the input) to connect and disconnect the battery to ground.
