Author Topic: Splitter-Blend: Want to add footswitches  (Read 270 times)
aefpv
« on: February 01, 2021, 11:53:36 AM »
I have created the Splitter- Blend (http://www.runoffgroove.com/splitter-blend.html) and got it working, but I want to take it to the next level.  I want to add two foot-switches, one for each effects loop.  I would also incorporate LEDs.
I have looked through General Guitar Gadgets wiring diagrams for the 3PDTs.  I understand how to wire the switch, but where in the Splitter-Blend's wiring should the switches be placed?  I think I am having "brain farts."
Does anyone have a good solution and where in the wiring of the pedal should the switches be placed?
Thanks.
iainpunk
Re: Splitter-Blend: Want to add footswitches
« Reply #1 on: February 01, 2021, 03:02:12 PM »
wire the jacks like you would a PCB and wire the circuit on the places you'd wire jacks.
cheers, Iain
edit: are you working on Bread Board? if so, i have a cool schematic that has two loops and a clean blend
it does need a buffered Vbias, keep that in mind
« Last Edit: February 01, 2021, 03:12:19 PM by iainpunk »
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
GGBB
« Reply #2 on: February 02, 2021, 08:27:44 AM »
As Iain says - it's the same as a pedal.
aefpv
« Reply #3 on: February 02, 2021, 11:47:16 AM »
Gotcha.  Thanks for the help!
BJM
« Reply #4 on: February 07, 2021, 05:39:11 PM »
Not sure if I understand the question..... Do you mean two true buypass switches to switch between effect and dry for each loop? Or two switches to turn each loop of or on? In that case couldn't you use two SPDT's to send the outputs (before the blend pot) to ground? On pole to mute, the other one for the Led? As described here:  http://www.muzique.com/lab/splitter.htm, (although with an SPST switch)
If you take the output of the buffer before the send you could have a delay or reverb in the loop with trails (?). Or would that not work (or cause other unforeseen problems)?
