Author Topic: True bypass loop pedal, switch pop  (Read 261 times)
fiestared
« on: February 03, 2021, 03:49:51 AM »
I built a passive true bypass loop pedal with this schematic, https://images.app.goo.gl/Z2Xr5VkLsKt2mB8c6
When I engage it I get a loud pop, so thinking I might need a pulldown resistor on any other mod? Grateful for help! The pedal it is used with does not pop...
Re: True bypass loop pedal, switch pop
« Reply #1 on: February 03, 2021, 05:40:46 AM »
You can try a 2M2 or so resistor between every individual jack Tip & Sleeve..
(although Send Tip is grounded when loop is out of order..)
P.S.
I see you're using 3PDT switch so it should be more convenient to implement below configuration:
« Last Edit: February 03, 2021, 05:45:01 AM by antonis »
Phend
« Reply #2 on: February 03, 2021, 07:32:55 AM »
http://www.geofex.com/article_folders/millenium/millen.htm
Do many of you use this bypass, saw it on the engineers thumb post.
Ya sure you Betcha.
« Reply #3 on: February 03, 2021, 08:33:45 AM »
millenium2-wise, I use it on [nearly] every build.
".... just enough bling hardware to complement the quiet textured slip-proof pants ...." - customer appraisal of last pedal build.
