Author Topic: Rainbow Machine Clone Magic not working  (Read 463 times)
« on: February 03, 2021, 01:20:44 PM »
Hey guys. I built up the rainbow machine clone from pedal PCB ( leprachaun) and everything works just fine except the regeneration. It doesn't work at all when engaged. Any tips or somthing I don't see. I had the fv1 pre soldered. Could it possibly be something wrong with that area. I am also using  cd4069ube instead of a cd4069ub?
Re: Rainbow Machine Clone Magic not working
« Reply #1 on: February 03, 2021, 02:39:07 PM »
I found this:
https://www.pedalpcb.com/docs/Leprechaun.pdf
Unfortunately all it says is "schematic coming soon". So that's not much help.
If the Regen control is one of the the FV-1 Pots, you need to check that you're getting 0-3.3V from the pot's wiper when you turn the control, and that that voltage gets to the correct pin on the FV-1. If it's a hardware control...well, you'll have to trace it, since we've got no schematic. Sorry.
« Reply #2 on: February 03, 2021, 02:48:38 PM »
Thanks for the reply I will check when I get home.
A dude on pedal pcb actually gave me the schematic. It's not up on the site yet though.
https://forum.pedalpcb.com/attachments/pedalpcb-leprechaun-jpg.3801/
« Reply #3 on: February 04, 2021, 07:11:35 AM »
I need a login to view that, sorry.
« Reply #4 on: February 04, 2021, 10:58:56 AM »
Sorry about that. I just uploaded it to imgur. According to the diagram the regen pot is not one of the fv1s. I was messing around with the audio probe last night. I did get a bit of a different sound when I poked around the regen stomp switch and can hear a little difference when turning the regen pot. The sound was a little different  compared to when probed on the output jack. But nothing crazy. It's not doing that crazy feedback sound its supposed to do.
Thanks.
« Reply #5 on: February 04, 2021, 10:59:41 AM »
Rainbow machine schematic https://imgur.com/gallery/xMaxasc
amz-fx
« Reply #6 on: February 04, 2021, 01:32:54 PM »
Looking at your photo of the back of the assembled pedal...  the regen is turned on by the footswitch in the bottom right. If the right side of the switch is not working properly, you will never get any regeneration, so when on, the two poles on the right side should be connected together. Zero ohms.
Some of the pots on the schematic are not labeled the same as the final docs.
Regen= Magic
Dispersion= Tracking
Spectrum= Pitch
Color= Tone
This pedal only uses the internal FV-1 programs since pin 13 is grounded (and there is no serial memory chip).
regards, Jack
« Reply #7 on: February 05, 2021, 12:40:44 PM »
Thanks for the reply and info. I just tested the switch and got zero ohms so the switch seems healthy
« Reply #8 on: February 05, 2021, 03:59:24 PM »
What connects M1 and M2 on the PCB?
antonis
« Reply #9 on: February 05, 2021, 04:31:00 PM »
Not a superficially very healthy area:  :icon_wink:
amz-fx
« Reply #10 on: February 05, 2021, 05:04:15 PM »
The footswitch I mentioned.
The components to the right of the op amp in the bottom right corner of the pcb are related to the regen. I would replace the op amp and then check some solder joints in that area if the chip swap doesn't do it.
regards, Jack
« Reply #11 on: February 05, 2021, 06:25:43 PM »
Ah, ok. Thanks Jack.
+1 agree. There are a lot of parts in this area that could conceivably prevent the regen from working. Bad joint on one of those 1u caps, short across a resistor or diode, etc etc. Lots of possibilities. Check that part over carefully.
« Reply #12 on: February 06, 2021, 09:59:59 AM »
Antonis, jack, druid thanks so much for the replies here. They mean a lot. I will inspect that area later on today and switch out that Tl072
