3PDT switch tip came off
Started by mc50, February 11, 2021, 07:45:41 PM
mc50
Hello,
This is the second time this has happened to me: got a full kit from Musikding with whatever default 3PDT switches they send out with it (I'm guessing this one). I wire it up, all's well.
Then, after about 10 or 20 switch presses (with my hands, mind you, no feet, no hard stomping - I'm still in the sitting down near the pedal stage after the build is done) the tip of the switch comes off. Of 5 of their switches I've installed, 2 of them developed this fault. All of them still work properly, even without the tip.
This is not a dig at Musikding, bad batches do happen and I've not contacted them about it. Quite possibly they'd replace them if reported. But just curious:
  • Did this ever happen to you? If it did, how did you fix it? I'm hoping there's a way to reattach the tip so that I won't have to re-solder a new 3PDT in there.
  • Should I stay away from default 3PDT in cheap kits and instead order a bunch of more expensive ones to have on hand for future builds? Which 3PDT brands would you recommend?
  • While at it, should I just go for brand-name components instead of whatever comes in cheaper kits (e.g. WIMA caps, etc.)? I know you'll probably say I should just buy the PCB if I'm going to replace the other components (or go with perfboard, etc.), but I'm not quite up to perfboard level yet (plus I'm having a hard time accepting that I should just attach it with double-sided foam tape to the pots), and I definitely can't drill an enclosure - so for kits where the PCB is soldered to the pots / switches I have to go with a full kit to get the pre-drilled enclosure.
iainpunk
welcome to the forum
1) yes, once, from a cheap chinese seller, 20 for $6, only one failed so far, so thats way better than expected. i re-attached with gorilla glue.
2) i have had reasonable quality cheap a$$ parts, so i woulnd't dash out the cash for expensive premium parts.
3) Name-Brand components are overrated, just get foil caps, ceramics can have bad properties. i only use tropical fish and paper-oil caps becaue i have them for free, i wouldn't pay extra for such MOJO nonsense.
cheers, Iain
cheers
mc50
Thanks! Just for the record, here's the Fuzz Face 3PDT (which I did bother to replace):
anotherjim
If the top is only a push friction fit, then that outcome is inevitable, although hopefully not this soon or easily so somebody released parts that were not made to spec.
I'd rescue it by filling/cutting some narrow grooves around the spigot, thoroughly degrease both parts and fit back with epoxy or a gel cyano adhesive. Real engineers would cross-drill and pin!
I'd just mix up a tiny bit of JB Weld and pop it back on, skipping jim's additional prep. I wouldn't necessarily bet that my repair would be as good as his, but my method would let me look at a broken switch for less time (unless it breaks again, of course).  :icon_wink:
iainpunk
> crosdrill and pin
how about not drilling pot metal, that stuff breaks if you put to much pressure.
cheers
cheers
mc50
Quote from: iainpunk on February 12, 2021, 08:11:13 AM
> crosdrill and pin
cheers
I guess that's a good warning to have in print for readers of this topic, as for me I wasn't going to drill the switch - I just don't have the proper setup to keep it safely in place, which is also why I can't drill my own enclosures.
iainpunk
QuoteI guess that's a good warning to have in print for readers of this topic, as for me I wasn't going to drill the switch - I just don't have the proper setup to keep it safely in place, which is also why I can't drill my own enclosures.
i dont have a  ''''propper'''' setup as well, i just squeeze the box in-between my legs and use a cordless drill with a pine tree bit. works every time. i have only hurt myslef once drilling boxes, and that was on a sharp burr.
cheers, Iain
cheers
anotherjim
What is "pot metal"?
They drill & pin fit wah pot gears - unfortunately, you can't then get them off!
iainpunk
cheers
The metal-monger's answer to the "mystery meat" served in school cafeterias.
DIY Bass
Quote from: iainpunk on February 12, 2021, 06:07:13 PM
https://en.wikipedia.org/wiki/Pot_metal
cheers, Iain
Wow.  I had the exact roller that is photographed in that link when I was a kid.
anotherjim
Ah, that stuff. I know it by a trade name "Mazak" used by most UK toy companies like Meccano, Dinky, Corgi etc back when those products were made here. Also known as zinc-diecast. Zink rot or Zinc pest doesn't occur for some time, although the Chinese have produced crap that barely lasts 5 years.
You cannot weld/solder/glue together, there has to be a mechanical fastener. It most definitely can be machined and a pin has to be the best size for a friction fit - or obviously, it will split. Other fasteners found include tapped for screw, self-tapping screw and rivets.
stallik
Quote from: iainpunk on February 12, 2021, 10:21:03 AM
You'd only have to hurt yourself once. You'd never forget it :icon_eek:
anotherjim
No, you'd need some machine shop equipment to hold the part securely, a drill that can do the correct speed and doesn't have runout/wobble. Your hands should be nowhere near it.
im guessing jb weld is the same as chemical metal in the uk?.
anotherjim
JB Weld has so many different products, I wouldn't know which is meant by the brand name alone. It would be the "original" I suppose...
https://www.jb-weld.co.uk/jb-weld-guides?lightbox=dataItem-jrkq8fwa
There are really umpteen brands selling similar ranges and they are all the very best thing in the universe and will stick to most kinds of everything forever.
I think JB-weld is epoxy while Chemical Metal is polyester. The practical difference is that polyester hardens before you need it to while epoxy hardens after you need it to.
True, JB Weld is a brand name, but it also a product name under that brand name, so look for the name appearing twice on the package, I suppose. :icon_wink:
This is specifically what I was referring to.  It is steel reinforced epoxy.
