Author Topic: Wiring 69 fuzz issue  (Read 868 times)
rangermaster
« on: February 15, 2021, 11:14:51 PM »
Hi there. Have a little issue here..
I used this layout http://diy-fever.com/wordpress/wp-content/uploads/2012/04/fuzz_face69.pdf and made a tagboard layout out of it (That's what i prefer). which you can find here: https://www.dropbox.com/s/8n1nzynkyfzkasu/20210215_201320.jpg?dl=0
i started wiring but when i connected all of it it didn't work. I also have a photo of the resistor and transistor wiring i did on the tagboard here: https://www.dropbox.com/s/2und0yl6goa62s8/20210215_201340.jpg?dl=0 (no caps and pots etc yet)
Can you help me out? and where do i put the red/black wires from the battery clip ?
I've seen on the photo on diy.fever site that the 2.2nF has to be 2.2uF like the original pedal.
Thanks for the help.
antonis
Re: Wiring 69 fuzz issue
« Reply #1 on: February 16, 2021, 04:58:46 AM »
So, finally you did posted it on air..  :icon_lol:
stallik
« Reply #2 on: February 16, 2021, 05:05:16 AM »
Antonis  - you been debugging this one privately too?
« Reply #3 on: February 16, 2021, 05:30:18 AM »
The battery black lead connects to where the Contour pot and the 33k resistor join.
The battery red lead connects to the orange wire that goes to the Gain pot.
On your hand-drawn layout it looks like you have the collector c and the emitter e swapped on both transistors.
Please check.
It would be wise to start-off with 2u2.   Most Fuzz-face circuits have 2u2 but you can tweak the value to knock out some of the woof.  2n2 is going too far for sure.
rangermaster
« Reply #4 on: February 16, 2021, 05:36:50 AM »
Thank you!
Yeah i have some 2.2uF(2u2) laying around so i can use those.
When i look at the fever layout and mine i can't see that i'm wrong with the transistors... ?
Ps: to the other members.. i got told/asked to put in on the forum. So i did.
« Last Edit: February 16, 2021, 05:38:35 AM by rangermaster »
« Reply #5 on: February 16, 2021, 05:56:55 AM »
If you are using germanium PNP transistors like the original '69 the fever layout has the e and c swapped.
The only thing I can think of is they are using PNP *silicon* transistors and *deliberately* swapping e and c.  Perhaps not guaranteed to work doing that and definitely not what the original '69 did.
rangermaster
« Reply #6 on: February 16, 2021, 06:11:02 AM »
Ok yeah i am using NOS germanium OC72 transistors (metal can).
So i should swap C and E on both transistors. Resistors can stay put ?
« Reply #7 on: February 16, 2021, 06:42:52 AM »
Yes.
The collector is often marked with a painted dot, base is the middle lead and emitter the remaining lead.
The schematic is here.  For example, Q1 emitter to ground (+9V),
https://guitarwork.ru/electronic/firm/Distortion/Fulltone%2069%20Pedal%20fuzz.jpg
rangermaster
« Reply #8 on: February 16, 2021, 06:55:52 AM »
Ok thanks. I'll keep the resistors in place and swap the transistors tonight. Thanks!
iainpunk
« Reply #9 on: February 16, 2021, 10:28:15 AM »
in the first link of your first post, the Bias and Contour pot names are reversed!
noticed that when i build it a few years back
cheers
rangermaster
« Reply #10 on: February 16, 2021, 10:41:56 AM »
cheers
Oh in the diy-fever layout you mean ? Switch wires then ? Cause contour pot is 1k and bias is 50k standard..
iainpunk
« Reply #11 on: February 16, 2021, 11:41:26 AM »
cheers
yes the DIY-fever layout, no only the NAMES of the pots are wrong... switch labels.
cheers
rangermaster
« Reply #12 on: February 16, 2021, 12:04:30 PM »
cheers
cheers
Ok are you really sure? Cause all the schematics i find have the same wiring....
Contour: 1k, 220ohms
Bias: 2.2uF, 1M
Do you also know(or any one else) how to wire it for negative ground and keep the pnp trannies ?
« Last Edit: February 16, 2021, 12:09:08 PM by rangermaster »
« Reply #13 on: February 16, 2021, 06:23:50 PM »
The original pedal which matches the schematic I posted earlier had the pots arranged like this,
Pots Left to Right, as viewed from front of pedal
Volume      500kA
Bias      50kB   ; clockwise closes pot
Contour      1kB           ; clockwise opens pot
Fuzz      1kB
The Bias and Contour controls make the pedal louder when they are turned clockwise.
And yes, the Bias control isn't what electronics people would call a bias control but that's how the pedal was.
A second source of info is the Guitar Gadgets site.
There's a few versions of the '69.  I don't know what changed on later versions, if anything.
« Last Edit: February 16, 2021, 07:24:24 PM by Rob Strand »
rangermaster
« Reply #14 on: February 17, 2021, 12:25:04 AM »
Volume      500kA
Fuzz      1kB
I found this somewhere..
Fuzz" = Gain
"Countour" = Bias
"Bias" = Input Level
"Level" = Output Level
antonis
« Reply #15 on: February 17, 2021, 04:49:23 AM »
Does Pots nomenclature affect pedal's function...??
e.g. You can also meet a pot between two distinct amplification stages named Sustain, Distortion or Volume.. :icon_wink:
« Reply #16 on: February 17, 2021, 08:03:51 AM »
The naming of the Bias and Contour pots on that pedal is very confusing.    Unless you have see it before it's fairly normal to think there is something wrong with the schematic/wiring/pot values etc.
Another weird thing about that pedal is the Contour pot (which changes the Q2 bias voltage ) is wired into the top resistor so it gets a lot louder when the Q2 collector voltage is set to a low value.
« Reply #17 on: February 17, 2021, 08:51:18 AM »
.... expander, swell.
iainpunk
« Reply #18 on: February 17, 2021, 08:57:50 AM »
drive, harmonics, gate, boost.
Fuzz" = Gain
"Countour" = Bias
that's also how i re-named the pots, i assumed there was a mistake in the names
cheers
rangermaster
« Reply #19 on: February 17, 2021, 01:26:35 PM »
Ok..
Tried wiring it again today. I swapped the transistors and connected the red lead to emitter q1 and the black lead where 33k and 1k pot meets.
Doesnt work.. nothing.
But after some ground checks and wiring the fuzz pot in a different way it works.
Now i have this layout: https://www.dropbox.com/s/l5fd09rjes1mwrx/20210217_204436.jpg?dl=0
One more question..... the fuzz has to work on a 9v battery.. but how exactly do i wire the battery leads so it doesn't drain the battery when the cable is out of the in/output ?
« Last Edit: February 17, 2021, 02:48:40 PM by rangermaster »
