Author Topic: PT2399 delay signal mix question  (Read 152 times)
matmosphere
« on: February 17, 2021, 07:22:18 AM »
Is it possible to take something like the Deep Blue Delay and split the dry and wet signals to separate outputs by skipping the mix pot and having two outputs?
Basically I want to experiment adding other effects to each signal separately. For example, a vibe to the original signal and a fuzz to the repeats?
11-90-an
Re: PT2399 delay signal mix question
« Reply #1 on: February 17, 2021, 07:34:36 AM »
Yup..  8)
flip flop flip flop flip
matmosphere
« Reply #2 on: February 17, 2021, 08:45:40 AM »
excellent, thank you
iainpunk
« Reply #3 on: February 17, 2021, 05:49:14 PM »
you might want to experiment with adding some FX loops. i suggest a clean path loop, a pre-delay loop and a post-delay loop, so you can still use the internal mixer.
cheers
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
