Author Topic: Replacement for NTE996 needed :(  (Read 391 times)
KarenColumbo
« on: February 17, 2021, 02:43:45 PM »
Seems I lag behind the world's progress. While I was idly surfing the web the wondrous "Jangle Box" compressor was brought to my ears' attention - what a nice stompbox, I thought. As I still like to etch the hell out of copper layers, solder multicoloured items, and drill aluminum enclosures to death I decided to give this one a go. At pedalpcb there is a schematic readily available, but my initial euphoria was suddelny tainted by the fact that the OTA IC that's in use in this thing ("Byrdhouse") is a whiff from the past - it's almost unobtainable here in Europe (Switzerland has a few, but the parcel delivery would be right over 45 Euros).
After some additinal surfing I gathered that the NT996 in itself is an alternative to the famous CA3080 - which, due to unobtainabilty, can itself be theoretically substituted by the more common LM13700. Or so.
Is that true? What will be the pitfalls of such an endeavour?
The schemo mentioned by me earlier can be found right at this link, page 3 of the doc: https://www.pedalpcb.com/docs/Byrdhouse.pdf
(Edit: The YouTube clip that caught my attention: https://www.youtube.com/watch?v=fJLBmDwd2Zc)
« Last Edit: February 17, 2021, 02:46:53 PM by KarenColumbo »
I want something that'll give me the stamina of a young werewolf, the vision of a shaman, the thoughts of a serial killer and the gentleness of a hungry vampire bat. - Spider Jerusalem
Kevin Mitchell
Re: Replacement for NTE996 needed :(
« Reply #1 on: February 17, 2021, 03:46:17 PM »
I thought that NTE's inventory was just rebranded NOS items?
It's definitely a 3080.
Alfa had started making a AS3080 recently. Which honestly - is probably repurposed wafers from their quad 13700 IC. But I'm just spitballing.
I'm archiving all of my DIYLC work for the home-etchers - Project Layouts & Templates
Marcos - Munky
« Reply #2 on: February 17, 2021, 05:54:19 PM »
iainpunk
« Reply #3 on: February 17, 2021, 06:12:46 PM »
NTE996 is a CA3080 without a TO-5 can package available, the wafers are identical.
i didn't know CA3080's are hard to find??? my local electronics store had them a few years ago for 2 euro, which i found quite expensive to be honest. but if i look up the prices now, they are going for 3 euro online...
i have a few laying around somewhere, i should build a tremolo.
cheers, Iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
KarenColumbo
« Reply #4 on: February 18, 2021, 01:15:20 AM »
Ha! Seems I somehow tricked Google into not showing me the right search results :) Just re-calibrated my internal (vintage) spelling systems (= brain), searched again, and found banzaimusic.com who indeed do offer CA3080s in abundance! Thank you very much for setting me right here!
(Also: this THAT 4316 looks promising. At least that's what I thought perusing the app notes THAT thankworthily provide)
« Reply #5 on: February 18, 2021, 08:44:11 AM »
that birdhouse circuit, on a quick glance, looks verry reminiscent of the dynacomp/ross/etc compressors.
"I think we're done here."
« Reply #6 on: February 18, 2021, 08:50:22 AM »
But is there a companion duckhouse envelope filter?
The internet:  answers without the need for understanding.
« Reply #7 on: February 18, 2021, 09:20:10 AM »
The AS3080E has significantly better numbers than the original CA3080. Most of the numbers match the CA3080A which was the "best-of" selected version. Other numbers are better than that. For example, the gain control range is linear for another decade. The "E" is for extended, since it also includes linearisation diodes like the 13700 if you choose to use them (improves S/N further, but makes the approach to distortion more abrupt). I've played with it and to me it seemed noticeably quieter and less prone to feedthrough and thumping. S'a nice little chip.
« Reply #8 on: February 18, 2021, 09:30:48 AM »
Frostwave funk-a-duck.
« Reply #9 on: February 18, 2021, 09:44:59 AM »
good one!  ;D
« Reply #10 on: February 18, 2021, 10:40:25 AM »
I'll once again mention my favorite compressor.  :icon_wink:
http://www.thatcorp.com/pedals/4316%20Battery-Powered%20One%20Knob%20Squeezer.pdf
"There is a pestilence upon this land. Nothing is sacred. Even those who arrange and design shrubberies are under considerable economic stress in this period in history." --Roger the Shrubber
KarenColumbo
« Reply #11 on: February 19, 2021, 07:29:37 AM »
Ive already been requesting estimates for bionic eye and solder iron replacements the last few weeks for this particular IC. Sadly out of my fincial scope. As are the necessary reflow oven and stencil subscription.
« Reply #12 on: February 19, 2021, 09:03:01 AM »
Just buy an adapter board and drag solder it (apply some liquid flux to the board, line up the chip, drag copious amount of molten solder across all the pins, then remove the excess solder with some braid or a solder sucker, then clean the excess flux with a toothbrush and some alcohol).  Takes a couple minutes, and you can use any soldering iron tip you like.  :icon_wink:
KarenColumbo
« Reply #13 on: February 19, 2021, 12:14:25 PM »
Yeah, I already Eagle'd such a board today (and tried to scrounge a handful from THAT Corp  :icon_biggrin:) - I did quite a few FV-1s this way, but the 4316 is really another dimension - it fells to me like it almost invisible. Quite a challenge. SOlder braid is an excellent idea - the sucker is too bulky for my taste.
