Author Topic: AION Comet DS1 - sound is a low fuzz  (Read 486 times)
broomhandle
« on: February 17, 2021, 06:06:19 PM »
Hello Everybody,
I have built a Lion DS-1. I chose the vintage build. I get sound when engaged. Volume and tone work. The distortion knob does nothing. It sounds like a low "tone turned down" fuzz. Pictures attached.
any help?
antonis
Re: AION Comet DS1 - sound is a low fuzz
« Reply #1 on: February 17, 2021, 06:29:25 PM »
Check continuity between DIST pot lug 3 -> R10(47k) -> C7 (1μF) -> GND
If something there is "open", IC1A acts as a buffer (unity gain) so the only distortion comes from Q2 preceding stage..
iainpunk
« Reply #2 on: February 17, 2021, 08:58:01 PM »
i suggest you lookt at this link:debugging guide
cheers, Iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
broomhandle
« Reply #3 on: February 18, 2021, 08:15:04 PM »
Thank you, I am testing now. Trying to figure it out...
broomhandle
« Reply #4 on: February 22, 2021, 04:13:50 PM »
Hello,
thanks for helping. When we are talking Left and Right, I think we are talking about from looking at the top.
My results are odd (Left and Right) I am not the best with a DMM... here are my results. :)
1.) DMM on cont. red prob on dist lug 3, black probe on R10 right leg.  = no beep on right leg ( - ), but beep on left ( + )  (looking from top down)
2.) DMM on resistance. black prob on dist lug 3, red on R3 =   I get no reading.
3.) DMM on cont. black prob on dist lug 3, reg prob C7 = no beep on either leg.
4.) DMM on cont. Red prob on C7, black on ground. = beep on ( - ) right leg. no beep from left leg (+)
antonis
« Reply #5 on: February 22, 2021, 05:03:54 PM »
I might confused you about Left-Right, so here it is:
broomhandle
« Reply #6 on: February 22, 2021, 05:43:25 PM »
I think I am more confused now.
so for C7, are you saying left leg as in (+) or (-)
and for 1-3. the red prob should be on lug 3 of dist pot?
I think this is right... photo attached...
sorry if I am more confused now.
antonis
« Reply #7 on: February 22, 2021, 05:56:31 PM »
Forget about DMM probe polarity, either for continuity test or resistance measurement..
(you don't read your P.M.s thoroughly..) :icon_mrgreen:
C7 Left leg should be the one marked (-)
As for R10, place one probe to pot lug 3 and the other probe to one of R10 legs..
You have two options:
1. Beep -> OK
2. No beep -> turn to resistance measurement mode -> 47k -> OK (no need for other leg beeping now..)
broomhandle
« Reply #8 on: February 22, 2021, 08:24:53 PM »
Ok..
1.) LUG 3 > R10 = a beep on the left side. "Picture attached". If that is not correct. I can do this:
2.) Lug 3 > C7 Right (+) = No Beep
3.) C7 Left (-) > Ground = Beep
Sorry if any confusion. I am a novice. I just thought this is fun, until one has issues.. thank you again everybody for helping.
antonis
« Reply #9 on: February 23, 2021, 04:29:13 AM »
OK.. :icon_wink:
Now measure resistance between pot lug 3 and C7 right (+)..
broomhandle
« Reply #10 on: February 23, 2021, 11:57:35 AM »
at 200k I get 4.5
antonis
« Reply #11 on: February 23, 2021, 03:30:48 PM »
So, NFB gain branch is OK..
Check for pot lug2 & lug1 connections..
broomhandle
« Reply #12 on: February 23, 2021, 05:29:00 PM »
So now check Lug 1 and 2: resistance  C7 right (+)..
the connections of lug 1 and 2 solider looks good.
antonis
« Reply #13 on: February 24, 2021, 05:17:33 AM »
Sorry but I tend to forget your initial issue..  :icon_wink:
So, let's get it from the beginning:
Check all pot connections to respective items..
e.g Lug 1  to IC1A pin 6, C5, C6 & R12..
Lug 2 (wiper) to C5 & R9
R9 to IC1A pin 3..
broomhandle
« Reply #14 on: February 24, 2021, 03:02:56 PM »
I am a little confused again. Are you asking to get continuity (beep)? or a measurement?
Lug 1  > IC1A pin 6, C5, C6 & R12
Lug 2 > C5 & R9
R9 to IC1A pin 3.. (?)
R9 to IC1A pin 3..
antonis
« Reply #15 on: February 24, 2021, 03:15:04 PM »
Check for proper connection and value of everyone item and wiring inside red frame..
