Just threw together a quick test circuit to put together a Diaz style square face fuzz. Using some GE OC44s - everything seems to be hooked up ok and it seems to sound pretty good, but the bias on Q2 with the stock values sits right around -6.6v and would take increasing the 8.2k resistor way up to around 20k to get it to down to the -4.5v range. Just curious as to why this might be, the transistor gains are up around 115 (which is around what most original diaz pedals I've had were) and both have low leakage. Curious as to whether this is natural for this circuit, the main resistor swap is 470 to 1.2k and 2k Fuzz pot. I did notice that the 'hendrix mod' is basically the same circuit and it has the 8.2k resistor swapped out to 18k which makes more sense given my situation. Every original diaz I've owned has the 8.2k in place.
Thoughts?
