Author Topic: Presenting...”The Prototyper”  (Read 1224 times)
Big Monk
« on: March 04, 2021, 07:09:41 PM »
I’ve been contemplating a more substantial breadboard setup for about a month now. I knew I wanted it to exist inside an enclosure so I could prototype/breadboard under normal noise conditions and observe the grounding and wire placement practices of a completed pedal.
Here is “The Prototyper”:
I used the DD enclosure so I could have 8 pots on the face. I figured this would allow for normal controls, controls for external bias, and a few other external controls t9 play with component values. I gave myself test ports for checking bias externally.
The power section has a dc jack with jack mounted charge pump circuit. I have a switch for selecting between +/- 9v nominal supply and a test port there to check the polarity of the voltage.
Just need to wire a few things to make it compatible with the breadboard (switches, etc.)
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” Aristotle
"Beneath the bebop moon, I'm howling like a loon, for you..." Marc Bolan
Re: Presenting...”The Prototyper”
« Reply #1 on: March 04, 2021, 08:36:56 PM »
I've sometimes wondered about something like this, but I never did it because I figured it'd never have the right pot value in it, or it'd have a linear when I needed a log or whatever. But maybe it makes sense, I dunno. I can certainly see advantages too.
Can we have a report on how you've found it and how you use it in six months time, please? ;) I'd love to know!
Big Monk
« Reply #2 on: March 04, 2021, 08:44:08 PM »
Well, I just recieved a Tayda order with 10 of every resistor from 82 ohm to 2.2M ohm, 8 of every capacitor from 10pf to 100uf, and a smattering of pots to cover about 30 circuits in my stash.
I have a whole gang of chips, transistors and diodes so I can build and tweak all the circuits I set out to.
BTW, the Tayda order was only about $50 for all the components. So, not a huge dent in the wallet to have any component value you need at your disposal. Granted, I went with 1/8 watt resistors because they were cheaper and there are no circuits I’m interested in that will dissipate enough power across these to be a problem.
I’m thinking I’ll post up some threads as I breadboard a circuits. Tweaks, thoughts, video, etc.
« Reply #3 on: March 04, 2021, 11:13:23 PM »
How well do the leads of the resistors plug into the breadboard? I couldn't use their 1/4w with my boards as the leads were too flimsy.
dave
kaycee
« Reply #4 on: March 05, 2021, 03:09:16 AM »
I have a flat board with a breadboard attached and a batten with in/out jacks, power and bypass mounted on it. There is 'table' space next to the BB to lay a schematic, meter or parts to swap out on. For pots, I have a range of trim pots mounted on vero with sockets for flying leads. I realise that the trims only give me linear taper, but most of the time, I just want to see if something works or not. The whole board, loaded, slides under my work bench on top of my parts drawers so it can get put away and out as the 'honey do' orders come in :icon_lol:
Big Monk
« Reply #5 on: March 05, 2021, 07:07:46 AM »
dave
Even the skinnier 1/8w leads plug in fine. I usually trim them short anyway.
Radical CJ
« Reply #6 on: March 05, 2021, 08:09:52 AM »
I've built a few things like this with a range of pot values soldered to bananna pins, but always find i need more pots of some value or another and still end up with alligator clips all over the place. Great for fuzzes/distortions, but lately I've found the ideas take up more and more bread boards. More pots and switches. More bananna pins...
Big Monk
« Reply #7 on: March 05, 2021, 10:24:27 AM »
I agree here. One thing I will say is that I went through schematics for about 20 or so pedals, mostly vintage dirt, a few overdrives, etc. and made a list of the required pot values. Then I made a list of some typical “flying lead” values and ordered those as well. The. I grabbed the whole range in trim pots on top.
I only plan on us No this to live with a pedal for a while, hammer out what I like/don’t like/find useful, then transfer the final form to a finished pedal.
Radical CJ
« Reply #8 on: March 05, 2021, 04:58:52 PM »
You have managed to fit a lot of pots on there, so for fuzzes and distortions you'll be able to use pots instead of some of the key fixed resistors and try the circuit out with multiple guitars/amps to see what fixed value will work best. Plus having the the prototype circuit in a tidy pedal enclosure means its easy to take around to other musicians' places to test it in a wider range of set ups.
Big Monk
« Reply #9 on: March 05, 2021, 07:56:41 PM »
This is kind of what I figured. Using short leads on components means things should stay in place and noise floor should be on par with a finished pedal because of the enclosure.
I think it will work out well. One of the critiques I have had with my own finished pedals is that I never give myself enough time to live with the pedal before boxing it up. I’m always wanting to test something else out which leads to flying leads and more holes and what have you.
This is a breadboard environment with a stompbox feel. I can change things at will and really hammer down on what’s what and then make an order and box it up.
mozz
« Reply #10 on: March 05, 2021, 09:45:36 PM »
You can get resistors by the hundred for very cheap from Mouser and others. Just built a few blue boxes and they use 11 resistors of 56k each. 1For some reason, i buy components from recognizedsurplus dealers instead of Tayda, especially IC and transistors. I'd rather old stock so i know it's not bootleg or fake.
 I do like that idea though. I usually just have a assortment of pots with 3 wires about 1ft long soldered on.
« Last Edit: March 05, 2021, 09:47:25 PM by mozz »
idy
« Reply #11 on: March 05, 2021, 11:33:57 PM »
Having the board upside down might jiggle things loose... I would think maybe use the box with the cover as a top and  have the pots on the side(s) of the box...or cut the lid in half and make half a shelf with pots and the other half that you open to fiddle around.
Big Monk
« Reply #12 on: March 05, 2021, 11:41:03 PM »
Components stay nice and tight with short leads so they are snug to the board. Plus, extra care will be taken given the setup. Won’t be stomping on the thing.
I did a test fit of the skinny leads on the 1/8w resistors (the limiting element) and they were solid as a rock.
iainpunk
« Reply #13 on: March 06, 2021, 11:57:20 AM »
that's a cool setup, i would have placed the knobs on the sides of the case tho, instead of on the top, but it looks great!
you can probably gig with that!! i know i would, well, i have gigged with worse breadboard setups, haha
cheers
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
Phend
« Reply #14 on: March 06, 2021, 12:04:47 PM »
Nice setup...
Dots of sillycon clear sealant will keep some components in place on that bread board. A whole tube will go a very very long way. At the same time touch up around the house.
« Last Edit: March 06, 2021, 12:07:14 PM by Phend »
Ya sure you Betcha.
« Reply #15 on: March 06, 2021, 12:37:49 PM »
handy for breading hi gainers......no squuuuuuuuueeeeeeeeeeeeeeeeeeeeeeeeeeeeeeelllllllllllllllllllllllllllll......
 8)
« Reply #16 on: March 06, 2021, 03:04:01 PM »
Nice setup...
Just don't use the sealant that contains acetic acid (smells like a UK chip shop!) 'cos the fumes eat any copper they come into contact with!
(We had a problem with this years ago at a place I once worked - caused a lot of expensive customer returns. Some units had been sealed with the wrong sealant, it ate the PCB tracks and we finished up doing warranty replacements of whole PCBs.)
Big Monk
« Reply #17 on: March 09, 2021, 07:31:24 AM »
Looks like I may finalize a few Tonebender MKII tweaks and then I’m tackling the Ampeg Scrambler.
iainpunk
« Reply #18 on: March 09, 2021, 09:03:29 AM »
ooh, nice one, its not to hard to get working, and easy to mod the heck out of it. i'd add an output buffer and volume control to the end, just so you can have it at lower volumes, instead of full all the time.
cheers, Iain
『snailpilled』
Big Monk
« Reply #19 on: March 14, 2021, 01:57:17 PM »
Was able to get most of the static stuff wired up today. Power rails and ground rails are tied together, jacks and switch are wired, including the shielded cables and tabbed washer providing chassis connection on the input, and charge pump is operational. I have the test jack wired to the center of the switch and the switch controls whether +/- 9v is provided to the power rail.
