Author Topic: My univox super fuzz pedal kit won't work  (Read 11059 times)
andy-h-h
Re: My univox super fuzz pedal kit won't work
« Reply #160 on: May 01, 2021, 07:21:11 PM »
somehow the 1st lug on the expand knob is grounded to the enclousure
It's supposed to be - have a look at the schematic
andy-h-h
« Reply #161 on: May 01, 2021, 07:24:45 PM »
wtf everything on the input jacks sleeve is grounded to the enclosure
The sleeve is ground, so that's OK, in fact it should work like this.  You need to be worried about the tip.
http://generalguitargadgets.com/pdf/ggg_superfuzz_lo.pdf
Go through your build with the black probe held firmly on the enclosure, and use the red probe to test everything that should not be connected to ground (black on the diagram).
Then check that everything that should be grounded, is grounded.
Test the switch in the on and off position.
« Last Edit: May 01, 2021, 07:29:03 PM by andy-h-h »
snow123
« Reply #162 on: May 01, 2021, 07:35:25 PM »
the tip on both jacks are grounded to the enclosure
snow123
« Reply #163 on: May 01, 2021, 07:39:54 PM »
and the pots are grounded where they should be
andy-h-h
« Reply #164 on: May 01, 2021, 09:39:57 PM »
That's quite a problem, but it should have an easy fix.
First make sure that the tip connector is not actually in contact with the enclosure.  From some of the photos you posted, the tip lug looks really close to the enclosure.
There's also some connections that look uncomfortably close on the board, any movement and they could short.
I can't see what's going on with the wiring or switch, however I would check the switch, as it looks a bit interesting.  I would go as far as to say that you will most likely find issues with the switch wiring.
Test continuity between the points that should not be connected, bearing in mind that this will change depending on the on/off status.
image from stew mac
« Last Edit: May 01, 2021, 09:51:57 PM by andy-h-h »
snow123
« Reply #165 on: May 01, 2021, 09:52:08 PM »
Here's some better pics of the footswitch, and the resistor the goes before the led is covered in electrical tape. And I checked continuity on the b2 and 0 pads and there doesn't seem to be a short or anything there.
eh la bas ma
« Reply #166 on: May 01, 2021, 10:08:55 PM »
i meant my DMM beeps when i put one lead on the leg and the other lead on the joint
I am not sure if it's helpful, but "grounded" usually means "connected to ground", I think there will be some confusion if you use that word to express the idea of connection between two points.
" ground or earth is the reference point in an electrical circuit from which voltages are measured, a common return path for electric current", " ground is the lowest potential in a circuit, for exemple the minus side of a battery or DC supply. "
"unity-gain non-inverting stage", "ground leg","post-pick moments", I love this colorful forum.
snow123
« Reply #167 on: May 01, 2021, 10:10:52 PM »
oh, sry for the confusion.
« Reply #168 on: May 02, 2021, 05:13:23 AM »
^^ yeah, this.
When you've been saying "grounded", you really mean "connected".
No wonder my head hurts!  :o   (Never mind the lack of coffee so far...)
snow123
« Reply #169 on: May 02, 2021, 03:29:27 PM »
but why is the tip on the output jack grounded?
« Last Edit: May 02, 2021, 03:40:59 PM by snow123 »
« Reply #170 on: May 02, 2021, 03:44:58 PM »
Very nice question and thank you very much for asking us..!!  :icon_cool:
snow123
« Reply #171 on: May 02, 2021, 03:52:26 PM »
y tho
snow123
« Reply #172 on: May 02, 2021, 03:53:01 PM »
and i just checked the schematic and everything that should be grounded, is grounded.
snow123
« Reply #173 on: May 02, 2021, 03:55:44 PM »
wait so im assuming everything on the commons area of the footswitch should be grounded, so that would be including the tip of both the input/output jacks?
« Reply #174 on: May 02, 2021, 04:02:22 PM »
No..
IN & OUT jack SLEEVES should be grounded,,
« Reply #175 on: May 02, 2021, 04:13:09 PM »
OK.. just take a look below about grounding points,,
snow123
« Reply #176 on: May 02, 2021, 04:18:07 PM »
ik the sleeves should be grounded, im asking about the tip.
aelling
« Reply #177 on: May 02, 2021, 04:47:19 PM »
That's what we are trying to help you with, they shouldn't be grounded but they are being shorted by something. Like we been asking above are you making sure the tips are not touching the enclosure walls? If the tips touch the walls it shorts signal to ground.
andy-h-h
« Reply #178 on: May 02, 2021, 05:30:06 PM »
The middle pins on a switch are only called common, because they are always connected to either the pin above or below.
If the tip of the jack is grounded, the signal will go to ground, meaning no output.   Some switching systems ground the circuit input when it's switched off to reduce noise and other issues, they never ground jack tips.
Are you 100% sure that both of your jacks are functioning as they should be?  It is possible to twist them and mess with connections (I've done this once before).  As mentioned, there's still a possibility that they are touching the enclosure.
I think you are going around in circles at this stage.  I would suggest;
1) desoldering the jacks and stomp switch, test the jacks and switches
2) make sure the circuit actually works, which I don't believe you have done yet
3) redo your off board wiring, and make sure it passes signal when bypassed
4) put it all back together now that you know you have a working circuit, and switching system
andy-h-h
« Reply #179 on: May 02, 2021, 05:32:29 PM »
oops - accidental post    :icon_lol:
« Last Edit: May 02, 2021, 05:40:10 PM by andy-h-h »
