Author Topic: My univox super fuzz pedal kit won't work  (Read 9779 times)
snow123
Re: My univox super fuzz pedal kit won't work
« Reply #240 on: May 06, 2021, 01:45:05 PM »
snow123
« Reply #241 on: May 06, 2021, 01:46:26 PM »
Can you send me a link to where you had sourced the 2N2222A transistors?
There are photos on google showing mixed info. I'm wondering if the pinout varies between manufacturers. At this point I highly recommend you first hand verify the pinouts.
And again, address the solder joints. Practice makes perfect just don't spend too much time in one spot or you'll lose another pad.
https://www.amazon.com/Pieces-2N2222-Transistor-Through-2N2222A/dp/B07R4PFTSF/ref=sr_1_5?dchild=1&keywords=2n2222a&qid=1620322958&sr=8-5#customerReviews
pretty sure these are the ones i got
snow123
« Reply #242 on: May 06, 2021, 01:58:15 PM »
the pedal now lets through a VERY weak signal to the amp. but its only audible when the gain and volume is maxed out. but it doesnt let anything through when turned off
Kevin Mitchell
« Reply #243 on: May 06, 2021, 02:24:11 PM »
Do you have a multimeter with a diode test function? Try my suggestion on the previous page to verify the pins.
Since they're unbranded there's no way to find the applicable datasheet. So let's be sure we have the pins correctly. Then we move forward!
I'm archiving all of my DIYLC work for the home-etchers - Project Layouts & Templates
snow123
« Reply #244 on: May 06, 2021, 02:29:11 PM »
yes i do have one with a diode tester. and how would i test it? like where do i put the leads and whatnot
Kevin Mitchell
« Reply #245 on: May 06, 2021, 02:40:53 PM »
With NPN transistors the forward bias of base to emitter is greater than base to collector.
In diode testing setting, put the black probe to the base lead - we know it's pin two in either variant here. Place the red probe on pin one, record the reading. Now place the red probe on pin 3 and record the reading. The higher reading is the emitter.
I wrote that trying to follow this
https://www.electricaltechnology.org/2013/03/how-to-remember-direction-of-pnp-and.html
snow123
« Reply #246 on: May 06, 2021, 03:05:23 PM »
ok i got basically the same results as they got doing what they did in that article
Kevin Mitchell
« Reply #247 on: May 06, 2021, 03:52:31 PM »
So what's the verdict?
snow123
« Reply #248 on: May 06, 2021, 06:01:19 PM »
i guess the ones im using are pnp then.
Kevin Mitchell
« Reply #249 on: May 06, 2021, 08:48:02 PM »
andy-h-h
« Reply #250 on: May 06, 2021, 08:49:32 PM »
2N2222 transistors are not PNP, they are 100% guaranteed to be NPN.
andy-h-h
« Reply #251 on: May 06, 2021, 08:50:48 PM »
« Reply #252 on: May 06, 2021, 09:28:09 PM »
The internet:  answers without the need for understanding.
Kevin Mitchell
« Reply #253 on: May 06, 2021, 09:33:30 PM »
I very much suggest playing with your multimeter. Look up YouTube videos if it helps. Measure any parts you have lying around and understand what's what. I went back and seen that your meter has a transistor test function. Work your way to that. Learn about polarity and the basics so folks can help you out more adequately!
I can't tell you how many times I hit a brick wall simply because I didn't understand something. But once I can grasp what it is I'm seeing, better questions start to come to mind and I can communicate better. There's awesome folks here who enjoy helping and will continue to try and steer you in the right direction.
One final suggestion, don't box till it rocks.
« Reply #254 on: May 06, 2021, 09:40:25 PM »
I think the OP needs to state the problem again.  I read over it and get lost in the all the detours.
One other point, the audio probe doesn't necessarily have to produce a signal at every point in the circuit or on every pin of a transistor.  How much signal you get depends on the specifics of the circuit.
« Last Edit: May 06, 2021, 09:42:25 PM by Rob Strand »
« Reply #256 on: May 06, 2021, 10:27:51 PM »
Six EBC variants-- are any missing?
If you stick specifically to the P2N2222A it's only one variant.
but yeah, over the whole family of "2222" devices you have to be careful about the part and package number details.
snow123
« Reply #257 on: May 07, 2021, 01:03:01 AM »
o. i just saw the thing that said "BC 557 is a PNP Transistor" on the article so i assumed that the ones im using are pnp. my noob-ness is showing alot now
snow123
« Reply #258 on: May 07, 2021, 01:06:20 AM »
the issue is that the pedal cant get a full signal through when turned on ore off rn. at first it would let the dry signal through when off but now it doesnt do that either.
« Reply #259 on: May 07, 2021, 06:57:17 AM »
Shall we plz proceed to signal trace..??  :icon_mrgreen:
