Author Topic: 500k "guitar" volume pot on a Fuzz Face  (Read 791 times)
DJPsychic
« on: March 12, 2021, 05:22:41 PM »
Might be a dumb question, but if I put a 300-500k volume put on a Fuzz Face after the input, would this respond like the volume pot on a guitar?
I currently use the 50k fuller bias at the input, would bumping up to 500k give me more "cleanup" range?
Thanks as always  :icon_cool:
iainpunk
Re: 500k "guitar" volume pot on a Fuzz Face
« Reply #1 on: March 12, 2021, 05:40:17 PM »
yes, it does that.
the FF's i build all had that style ''gain control'' and had the other gain control hardwired at full gain.
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
DJPsychic
« Reply #2 on: March 12, 2021, 05:50:37 PM »
yes, it does that.
Nice! I typically have a 50k @ input, 1k gain, then 500k vol...will experiment with a 500k at input as well
Thank you!
iainpunk
« Reply #3 on: March 12, 2021, 06:54:16 PM »
ow, i use 250k for this 'trick' (and all my guitars), but 500k would probably be fine. you might want to put a 10k or 22k 'stopper resistor' in between the pot and ground
『snailpilled』
Big Monk
« Reply #4 on: March 12, 2021, 07:19:48 PM »
yes, it does that.
Unfortunately, the “Fuzz” control on a Fuzz Face is useless compared to the “Attack” pot on a Tonebender MKII.
I put this “Pre-Gain” pot on my Tonebender MKII and between guitar volume variations, “Attack” pot settings, and “Pre-Gain” settings, there is a whole plethora of distorted tones to be had.
« Last Edit: March 12, 2021, 08:08:52 PM by Big Monk »
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” Aristotle
"Beneath the bebop moon, I'm howling like a loon, for you..." Marc Bolan
DJPsychic
« Reply #5 on: March 12, 2021, 07:42:21 PM »
Interesting the "input" pot I use aren't grounded Just lug 1 and wiper. Also are you using linear or log?
DJPsychic
« Reply #6 on: March 12, 2021, 07:43:43 PM »
yes, it does that.
Unfortunately, the “Fuzz” control on a Fuzz Face is useless co pare to the “Attack” pot on a Tonebender MKII.
I put this “Pre-Gain” pot on my Tonebender MKII and between guitar volume variations, “Attack” pot settings, and “Pre-Gain” settings, there is a whole plethora of distracted tones to be had.
I love the sound of a rolled back fuzz  :)
ashcat_lt
« Reply #7 on: March 12, 2021, 08:20:45 PM »
The series resistance of your pot over the low input Z of the FF probably does fine for full range voltage division anyway, unless you really want to get to silence.  That same series resistance will also tend to isolate the inductance of the pickups from the low FF input, so you get some of the treble back at the same time.
More simply put, the FF input basically IS the grounded lug of the "pot" plus a stopper resistor already.  :)
« Last Edit: March 12, 2021, 08:22:37 PM by ashcat_lt »
iainpunk
« Reply #8 on: March 12, 2021, 08:44:44 PM »
i doubt it actually matters if you use it as series or with a grounded lug, the grounded lug would probably give you a deeper cut in gain.
i use log, for gain, volume, etc.
you can also add a bright cap if you want more distortion instead of fuzz when you turn down the gain.
cheers, Iain
『snailpilled』
DJPsychic
« Reply #9 on: March 13, 2021, 09:26:26 AM »
Edit:
More noob questions:
What are the tonal differences between using a B250k and a A250k in this position? Am I still accomplishing the same thing but on a different curve?
The A250k I have in does it's job cleaning up, but there's only about a 1/4 turn that has an effect on the signal.
I tried a B250 and a B500k - there seems to be a bit more useable range.
« Last Edit: March 13, 2021, 10:22:32 AM by DJPsychic »
anotherjim
« Reply #10 on: March 13, 2021, 11:15:47 AM »
Some have gone as far as building a guitar sim to go between a buffered pedal and ye olde fuzz.
Completely passive, a winding of an audio transformer in series with the input stands in for the pickup inductance with a guitar vol & tone to output.
I keep meaning to make one.
Croeso i Diystompboxes.
If they didn't hear you then you didn't say it.
iainpunk
« Reply #11 on: March 13, 2021, 05:18:52 PM »
i build something similar for a friend, using a ua741 with a gain trimmer from 0db to 6db (unity to 2x gain), going in to a guitar pickups with its magnet removed, and through a volume and tone pot like a strat is wired.
Edit:
it doesn't make a tonal difference wether you use log or lin pots, resistance is resistance, independent of the wiper sweep.
『snailpilled』
DJPsychic
« Reply #12 on: March 16, 2021, 06:56:34 AM »
Another few more noob questions:
- What is the actual difference between using the 500k pot and the 50? I understand it's "more resistance" but how is it effecting the original signal?
- Are both the 50k and 500k when maxed letting in original signal or are they "boosting" it to their respective resistance? Like am I effecting the tone the same with both pots, just on a wider range? Or am I adding more gain with the bigger value?
- With the 500k, It only really has in effect in the last 1/3 of a turn. Is there a way to just have that range of resistance spread out through the entire range of the pot? In other words, letting the user dial in a more precise tone.
Sorry for the clunky wording, these are probably super dumb questions. not an engineer, just really enjoy building fuzzes
Thanks again
« Last Edit: March 16, 2021, 07:10:04 AM by DJPsychic »
iainpunk
« Reply #13 on: March 16, 2021, 08:15:06 AM »
it depends, if its just in series with the input, wihtout going to ground, the 500k pot reduces the gain more, but they still have the same max gain.
if the lug is grounded, the 500k does a bit less loading on the guitar. when its on max, the input impedance of the fuzz face is low enough to ignore the pot value, but when you start to turn down, youll find a slight reduction in top-end with the 50k compared to the 500k, but it will probably be marginal.
all the pots do is take out gain, the 500k has a slightly different sweep and effect due to higher resistance compared to the 50k pot.
make sure to try both log and lin pots, and the log pot in reverse. that gives 3 sweeps, and you can choose the best in your opinion.
cheers, Iain
『snailpilled』
DJPsychic
« Reply #14 on: March 16, 2021, 09:18:12 AM »
Thank you for the thorough explanations and clarifying everything for me. Makes a lot of sense now
Yes, I'm just trying to find the best option. I want the full range of gain, without adding any at max (which you explained isn't the case).
Essentially trying find the most sweep for cleaning up gain. I've tried lin and log, but will have to try reverse.
I think the Lin had a more gradual sweep of the gain, where the log seemed abrupt. Want to make sure I'm not "missing" any of the sweet spots. That's where all the magic is for the FF in my opinion.
I guess I have to figure what is best value resistance to get the right amount of cleanup. 500k may be unnecessary.
iainpunk
« Reply #15 on: March 16, 2021, 10:35:08 AM »
i use 250k or 220k pots for fuzz face-based circuits, and i generally put a log in reverse (when you turn the control up, you turn the gain down) and call it "attenuate"
cheers,
『snailpilled』
DJPsychic
« Reply #16 on: March 16, 2021, 01:40:08 PM »
Will definitely have try that. I like the reverse idea, makes more sense aesthetically as well.
