Author Topic: Alcapulco Gold LTSpice [project help]  (Read 1012 times)
KingGeedorah95
« on: March 14, 2021, 03:27:57 AM »
Hi everyone,
I'm trying to characterize an Acalpulco Gold circuit in LTSpice. I've been using LTSpice for the past year during my electrical engineering degree so I'm familiar with the software but this is my first time trying to simulate a guitar pedal.
Here is what I go so far...
The pot and op-amps might be hard to read but they are 100k at 50% and LM386s
Now, I took the peak-to-peak of both Vin and Vout and obtained the gain. I multiplied Vin by the gain for verification and as you can see I've got a gain of ~5500. That's waaaaaaay too much isn't it? Wouldn't that be an upwards of +70 dB? Shouldn't it be something like +20? Idk. I can't find specs like this anywhere so please let me know if I'm wrong.
Am I using the incorrect input for my guitar signal? Right now it's set to 0.132 [mV] @ 1kHz. The rest of the schematic is in good shape, yeah?
FiveseveN
Re: Alcapulco Gold LTSpice [project help]
« Reply #1 on: March 14, 2021, 04:56:08 AM »
Hello and welcome!
Should be 40000-ish, it's a high-gain distortion, you will have a hard time getting a clean sine out of it. Which brings us to...
That's more like the noise floor of a guitar signal. Here's an article by Jack Orman that goes into some detail: http://www.muzique.com/lab/pick.htm
Does the circuit sound better when oriented to magnetic north under a pyramid?
anotherjim
« Reply #2 on: March 14, 2021, 08:55:18 AM »
The LM386 chip's datasheet does say the cap between pins  1 & 8 raises gain to 200. Total voltage gain with more than one stage multiplies by the gain of each consecutive stage. x3 followed by x3 is x9, not x6.
x5500 is too much, but I suppose there could be factors in the sim (noise & distortion?) and measurement (pk-pk vs RMS?) that can give such a large discrepancy because of the multiplying nature of the 2nd gain stage.
Croeso i Diystompboxes.
If they didn't hear you then you didn't say it.
« Reply #3 on: March 14, 2021, 09:13:41 AM »
does your sim program recognise R1 as 1Meg or 1milli? [I know 0 about sims.] and welcome.
"You ain't seen me, right?"
KingGeedorah95
« Reply #4 on: March 14, 2021, 11:42:17 AM »
Hello and welcome!
Glad to be here and thank you for the article!
KingGeedorah95
« Reply #5 on: March 14, 2021, 11:47:16 AM »
I managed to find this information from the datasheet that you might be referencing...
"9.2.1.2.1 Gain Control
To make the LM386 a more versatile amplifier, two pins (1 and 8) are provided for gain control. With pins 1 and 8 open the 1.35-kΩ resistor sets the gain at 20 (26 dB). If a capacitor is put from pin 1 to 8, bypassing the 1.35-kΩ resistor, the gain will go up to 200 (46 dB). If a resistor is placed in series with the capacitor, the gain can be set to any value from 20 to 200. Gain control can also be done by capacitively coupling a resistor (or FET) from pin 1 to ground."
So I am going to try removing the second gain capacitor and maybe placing a pot there for gain control. Even using Vrms instead of Vpp there is less than a 1% difference in gain which leads me to believe there is a different problem at hand.
Thank you for your response!
KingGeedorah95
« Reply #6 on: March 14, 2021, 11:50:12 AM »
Hahaha nope! I must've replaced 1Meg by mistake when I was doing some remodeling. I don't use Megs often so I am always forgetting that "M" isn't recognized by the syntax in LTSpice. Now that simulation looks like this...
There is some hard clipping on the output signal but that's desirable in a high gain/distortion pedal, isn't it?
I also changed my input voltage to 150 [mV] @ 640 Hz.
« Last Edit: March 14, 2021, 11:53:08 AM by KingGeedorah95 »
Vivek
« Reply #7 on: March 14, 2021, 04:25:15 PM »
Could you email me your LTSPICE file ? Thanks
KingGeedorah95
« Reply #8 on: March 14, 2021, 05:11:56 PM »
The link below should be shareable with anyone who uses it. All of the files are there including the LM386 .asy and .sub and the 1N4001 SPICE model. Let me know if you have any trouble accessing it.
https://drive.google.com/drive/folders/1dUwpvGqqzTOBoi_ezlWijx5tabg0q2hx?usp=sharing
Vivek
« Reply #9 on: March 15, 2021, 01:58:31 PM »
Will you actually build this circuit after SPICING it up ?
« Reply #10 on: March 15, 2021, 05:47:51 PM »
Me too. I *think* I might now have got into the habit of using my new favourite 999K resistor value!
KingGeedorah95
« Reply #11 on: March 16, 2021, 01:11:34 PM »
Yeah! So I made a breadboard build and it sounds decent. Have you ever built this one? Any mods I should be aware of? I want to add gain control to the second op-amp.
I found another schematic that is slightly different so I'm going to SPICE it up and breadboard that one to see which I like better. Then I'm moving over to perfboard it and fit it into a tiny little 1590A. Just being introduced to KiCad so I'm not going to do a full out PCB layout just yet.
KingGeedorah95
« Reply #12 on: March 16, 2021, 01:13:58 PM »
Hell yeah! Haha that's great. -1k ain't going to make a difference at that level anyway.
« Reply #13 on: March 16, 2021, 02:34:29 PM »
1000k is a legal value.
composition4
« Reply #14 on: March 17, 2021, 12:51:38 AM »
So is 0.001G
jdoughty
« Reply #15 on: March 17, 2021, 10:55:34 AM »
I just built this effect myself and it's awesome, so very excited to see if you can add a usable gain control! The variety of tones you can get with the volume knob is excellent, so I'm sure there's plenty of ways.
Vivek
« Reply #16 on: March 18, 2021, 01:39:07 PM »
Yeah!  I'm going to SPICE it up and breadboard
It would be great if you decided to calculate expected signal level and distortion percentage/ wave shape at each stage
Off the cuff, I would assume that gain of first stage should be around 80 for the gain control of the second stage to be meaningful
( I cannot calculate more precisely since it depends upon
output of guitar signal
and impedance of guitar pickup
and also your tastes : Do you want from almost clean boost to mayhem  ? or mid distortion to high distortion ?
And loss in the inter-stage Low Pass filter)
« Reply #17 on: March 18, 2021, 07:16:13 PM »
..both of which are widely variable, unfortunately.
A "guitar signal" is not a well-defined standard. In fact, the only way it *can* be defined is as "anything a guitar produces"!
Hence the effect of pedals that depend on gain and/or signal level for their effect is likely to be similarly variable. There's no way around this. The simplest solution is player-operated knobs that compensate for different signal levels, but then of course every player has a difference experience, which isn't ideal when people want to share "sweet spots" on the controls.
