Advice for Psych-Tone project
Started by theehman, March 23, 2021, 06:30:29 PM
theehman
For no reason whatsoever I've been working on a board layout for the Psych-Tone which is an old synthesizer /sequencer found in an old electronics magazine.  The main issues I'm having is the 6 bank interlock switches and the 24vdc/3.3vdc power supply.  I was wondering if there were any modern methods of replacing those.  I'd like to run it off an adapter if possible.
Ron Neely II
fx schematics and repairs
tonyharker
theehman
Yeah, but I want to have a physical version.
Ron Neely II
Where is this old electronics magazine?
That's switching insanity. The gang-switches are now rare, rotary switches now have different leg spacings (won't fit the PCB), and a LOT of wiring is by-hand. (Ah, you do your own layout.)
I doubt the actual switches matter; DPDT and 1P12T switches are still available. It wants interlock but I don't think anything smokes if not interlocked......
24VAC and 6VAC transformers are still around.
The UJT (not PUT) may be a hunt. And known-good RTL chips will be a real pain to source; TTL can work but with what mods? (page 49 gives clues)
The metalwork in Fig 11 is non-trivial.
Fig 8 S5 is drawn wrong. Better get the next 5 months and check errata.
Quote from: PRR on March 23, 2021, 11:09:54 PM
Here you go:  https://worldradiohistory.com/Archive-Poptronics/70s/1971/Poptronics-1971-02.pdf
Ignore the "Poptronics" title.  They're using the final publication name for all or most of the issues of Popular Electronics, going back a ways.
You can find those radio buttons, although they're not common.  I found some on the Bay (China, natch) and used them in my Blue Shift build:
theehman
I had a couple of the switch banks but forgot where I bought them.  A little more searching on ebay turned up a seller with a few still in stock so I bought those.    I have plenty of the 2N4871 FETs and most of the BJTs and mosfets as well as the MC791P.  I probably have some of the other RTL chips around here somewhere.  I guess now that I've found switch banks I won't need to replace the switching.  Probably going to power it with a 24VDC adapter with a tap off to a 3.3v regulated circuit for the RTL.
Ron Neely II
Quote from: theehman on March 26, 2021, 04:36:06 PM....Probably going to power it with a 24VDC adapter with a tap off to a 3.3v regulated circuit for the RTL.
Do your homework first. Lancaster gives an example of not-much-RTL-logic sucking 228mA:
https://archive.org/details/RTL_Resistor-Transistor_Logic_Cookbook/page/n25/mode/2up
Take that from a 24V source, you drop 24-3.6= 20.4V at 0.228A is 4.66 WATTS. He rounds-up to 0.25A, 5.1 Watts. A TO220 regulator will do this, with a not-small hunk of heatsink.
