Onboard wiring
Started by rangermaster, April 01, 2021, 03:13:49 AM
rangermaster
Hi
I would like to wire a Rangemaster pnp(negative ground) in to strat. (Using a 9v battery)
It should go on/off by a on/on toggle switch and the guitar controls should stay the same(1 vol, 2 tone). Also the Rangemaster should be wired to the volume pot so the volume can be controlled.
Is this possible? And how to wire this exactly ?
Another question... is it also possible to activate the battery with the switch or can this only be done by a stereo jack ?
Thanks.
Should this work ?
iainpunk
QuoteIt should go on/off by a on/on toggle switch and the guitar controls should stay the same(1 vol, 2 tone). Also the Rangemaster should be wired to the volume pot so the volume can be controlled.
well, wire a DPDT toggle as you would a foot switch!
a range master has its own volume control, the 10k pot, but if you leave the guitar's volume in front of the RM, like if it were a separate pedal, you can still change its volume over the full range using the guitar volume pot.
QuoteAnother question... is it also possible to activate the battery with the switch or can this only be done by a stereo jack ?
depends... do you like a huge loud POP when you switch on the RM? that you can use a 3PDT switch to switch its power, if you don't want a loud pop when switching, just get a stereo jack.
cheers
cheers
