Junkbox VD - 9 in 9 out issue
Started by stonerbox, April 05, 2021, 11:47:04 AM
stonerbox
Hi!
Edit: turns out top leg of C7 had a bad connection.
Zero increase in voltage is today's problem, actually goes down from 9.98 V in to 9.45 V out. I subbed the BC557 with a 2n3906 but use BC547C for the rest.
I swapped all transistors once just to be sure but and have also checked all connections (continuity), all cuts and the pinout of 2n3906, no problem there. I'm sure it just some very simple mistake on my part. Any ideas?
Q1
C 9.94
B 0.56
E 0.003
Q2
E 0.003
B 0.056
C 0.003
Q3
C 0.056
B 0.702
E 0.003
Q4
C 0.052
Q 0.703
E 0.003
https://www.diystompboxes.com/smfforum/index.php?topic=97141.0
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
stonerbox
Guess I was not done after all. When I measure the output it reads 16.2 volts, no problem there, but when I hook up the output to four opamps (buffers and filters) the volt goes down to 7 volts and Q1 gets very hot. I tried swapping Q1 but with the same results.
Q1
C 9.0
B 4.2
E 4.1
Q2
E 4.1
B 4.2
C 0.0
Q3
C 4.2
B 0.69
E 0.0
Q4
C 0.05
Q 0.70
E 0.0
When hooked up to OP-amps
Q1 Gets very very hot (have swapped same result)
C 8.99
B 2.5
E 2.4
Q2
E 7.5
B 4.1
C 0.0
Q3
C 0.052
B 0.69
E 0.0
Q4
C 0.05
Q 0.70
E 0.0
iainpunk
what opamps did you use?
this design can deliver only very little current, so driving more than a low current transistor circuit will suck the voltage down to 9v or even lower.
shouldn't expect much form something called ''junkbox''
cheers
cheers
stonerbox
Quote from: iainpunk on May 13, 2021, 02:16:32 PM
cheers
I had my suspicions that was the case.. well I use five OPA2134. Are there any better alternatives (voltage pumps) out there?
iainpunk
LOTS of options out there, just look at the Centaur circuit, it uses a dedicated chip, and google might help as well, look for ''charge pump'' circuits/chips.
cheers
cheers
stonerbox
#5
What about something like this? I got some CD4049s lying around and I am pressed for time and do not want to wait for an order of NE555s to arrive. Or would this one not produce enough current?
https://circuits-diy.com/12v-to-24v-voltage-doubler-circuit-using-cd4049-ic/
iainpunk
rule of thumb for most CMOS is an output current of less than 2mA per output, putting 4 parallel like this should give about 8mA, again, fun if you have a low current transistor circuit, but not useful for driving opamps.
for comparison, that OPA2134 can output 35mA.
not to say you should use that opamp for the charge pump, but to give you an idea of scale.
another comparison for schale, the NE555 can deliver 200mA of current, which is quite capable of driving a charge pump.
cheers
cheers
