Author Topic: tc electronic footswitch replacement  (Read 3514 times)
snow123
« on: April 14, 2021, 04:17:39 PM »
ok, so i spilled some water on my beloved tc mojomojo, everything works fine, but the footswitch gets stuck. and its a 2pdt switch and i only have 3pdt switches, and it has pins to connect to the pcb and all of my footswitches use lugs. so i connected 6 solid core wires to 6 out of the 9 lugs to connect it to the mojomojo's pcb. would this work?
snow123
Re: tc electronic footswitch replacement
« Reply #1 on: April 14, 2021, 04:28:13 PM »
« Reply #2 on: April 14, 2021, 04:34:19 PM »
You probably need to connect your six wires to 2 columns.. vertical
Rather than the 2 rows...horizontal.
So you have a dpdt......
« Reply #3 on: April 14, 2021, 04:46:48 PM »
Ice-9
« Reply #4 on: April 14, 2021, 04:51:35 PM »
I would suggest to buy the correct 2pdt footswitch as they are a little smaller in physical size (height) so for the sake of a few quid will make life so much easier to fit . Alpha 2pdt latching. On the other hand if you prefer to fit a 3pdt switch then vertical pin outs are the way.
www.stanleyfx.co.uk
snow123
« Reply #5 on: April 14, 2021, 04:59:25 PM »
I should also add a pic of how the stock switch is on there + how I would install my make-shift footswitch
« Reply #6 on: April 15, 2021, 04:06:03 AM »
Do what Mick says: the replacement switch is readily available.  You'll only have grief trying to get that 3PDT with its extensions into place (I'd wager you won't get switch+PCB to fit at all).
« Reply #7 on: April 15, 2021, 04:38:39 AM »
+1 to what mick and marc said....(now youve shown the pcb pics)
those switches are readily available with the pcb pins.  8)
solder sucker....and replace with same switch. done.  8)
« Last Edit: April 15, 2021, 04:40:23 AM by deadastronaut »
snow123
« Reply #8 on: April 15, 2021, 03:14:06 PM »
well the thing is that i cant really find any 2pdt switches that use those pins. i can only find ones with lugs.
« Reply #9 on: April 15, 2021, 04:23:31 PM »
What are the pin measurements?  It's an Alpha switch in the photo.  Looks like the ones you can get at Tayda or Small Bear, among other places.
snow123
« Reply #10 on: April 15, 2021, 11:18:21 PM »
lmao the solder connecting the footswitch to the pcb wont melt
« Reply #11 on: April 19, 2021, 07:28:24 AM »
this sounds like a paradox, but put your solder onto it, then suck....
it'll heat up better and flow.
Ice-9
« Reply #12 on: April 19, 2021, 05:18:47 PM »
As Rob said, Reflow new solder onto the pins before trying to de-solder. The solder on the original will be lead free solder and needs a higher temp to reflow. If you put new solder on using leaded solder then it is easier to remove the solder at the next step.
I know it sounds counter productive to add solder to remove solder but this is the way to do it.
Removing a footswitch without damaging the PCB can be tricky if you have not done it before.
www.stanleyfx.co.uk
